Old 01-27-2004, 01:55 AM   #1
who's got side exit exhaust?
I wanna put it on my charger, but my dad(ASE Mechanic for many moons) seems to think it would be very dangerous because gases can get up in the car. Hes ok with me going to take the cat off and run 3" exhaust, he wants me to run it out the back and have a semi-quiet muffler so I don't wake him up. If I can't get him to give in about the side exhaust, i'll just run a single center exhaust.
twyztedgt is offline
Old 01-27-2004, 04:21 AM   #2
My van does and the fumes only bother me when setting at a light with the window down and even then the wind has to be blowing the rightway. The big problem with it is I can't get any of the shady shops to give me an inspection sticker with it like this.
DarkWolf is offline
Old 01-27-2004, 08:45 AM   #3
same here.i have mine registered in s.c at my cousins house(no inspections):big grin: but fumes arent really an issue unless the wind blow just right with the windows down.also you lose about 10 lbs of pipe. any weight out of the rear is a good thing with these cars.
silvershelby387 is offline
Old 01-27-2004, 12:27 PM   #4
The onlt time fumes get in my car is when the door is open and the wind is blowing that way. window down hasn't seemed to be a problem.
89daytonaTII is offline
Old 01-27-2004, 04:08 PM   #5
im doing side exit but was thinking of going behind the front tire no in front of the rear.thats for the race car and something that wont be daily driven alot
csxt#10 is offline
Old 01-27-2004, 04:51 PM   #6
i am on the shadow... ive had NO problems with fumes and my oil seals are leaking..... little smoke, lol
TurboShadowES is offline
Old 01-28-2004, 12:04 AM   #7
My Ride: Dodge Omni GLH clone
Engine: 2.2 inline 4
I have had a side exit for 3 yrs. No problems, although I did notice a little suplhur stench right after WOT bursts, when I came to a slow or stop if I had the window down.(catalytic converter smell)
omnivore is offline
Old 01-28-2004, 12:22 AM   #8
My Ride: 85 GLHT, 87 ShelbyZ
Just point him in the direction of the new Mercedes SLR Now that's how exhaust should exit I love my 3" straight pipe side exit exhaust.
Later
GLHNSLHT2 is offline
Old 01-28-2004, 12:33 AM   #9
My Ride: 1986 Shelby Charger
Engine: 2.2 pseudo TII
I'm going to do a 3" side exit. Can somebody posta pic of their setup...do you have it hidden behind the gfx, or sticking out?
Would it be worthwhile go get another 90 bend to direct it toward the back of the car again and leave it like that?
The S is Silent is offline
Old 01-28-2004, 12:40 AM   #10
I have mine cut flush with the outer most curve on the lower ground effect on my 87 Z. I cut the ground effect just to give it some clearance over the pipe. Looks good. Can't tell it's anything other than stock if you didn't know it. I think it's best to get it out from under the car.
Later
Old 01-28-2004, 12:51 AM   #11
would you place it behind the front tires or before the rear tires? left right y it into 2 2 inch pipes ?
oh ya i saw plastic stick on things at walmart make it look like u got side exit pipes coming from like your 1/4 panel
ravenc is offline
Old 01-28-2004, 01:03 AM   #12
if you look under your car at the original exhaust pipe "channel" you'll see that abit after the cat is makes a 90* toward the drivers side. you just keep it going straight from there. If you look you'll understand.
best not to do it on the pass. side b/c it'd be right against the fuel lines.
Old 01-28-2004, 01:13 AM   #13
Exactly, exactly, exactly!
Old 01-28-2004, 02:23 PM   #14
I have a side exit on my omni glh (previous owner installed it) and I don't like it that much because it has to sag a little, if it's pulled up tight to the chassis then it would melt the side-skirts, but when it's sagging it scrapes speed bumps. It necks down in a few areas to like 2 inches, so i'm upgrading to a full exhaust out the back, it'll be better performance, quieter (with a muffler) and more ground clearance
beefalobilly is offline
Old 01-28-2004, 02:48 PM   #15
My friend runs 3" side exit on his 86 GLHS. He has it pulled up tight. Heck I did it for him. Ground F/X are unneffected.
Later
Mortgages | Manage Depression | Loans | Remortgaging | Homeowner Loans
Page generated in 0.48605 seconds with 14 queries
