03-02-2004, 06:43 PM
NO Democracy!
Originally posted by iTurbo
The VNT exhaust manifold is the same as the T2, except for the VNT manifold has a higher nickel content and has a stud on the turbine flange where the T2 uses only bolts.
Correct. The VNT's is made Ny-cast or Ny-resist... I can't remember... but CRACKS. All the ones from VNT cars I have pulled off were cracked. Same material was used for the turbine housing, too. (I believe)
Also, the FM ported VNT manifold is simply a stock T-1/T-2 manifold that has been modified to accept the one stud. I bought one from them years ago. Wish I knew that then.
