Old 03-02-2004, 10:11 AM   #1
Putting 3" on van tomorrow, tips/suggestions?
My Ride: 89 Caravan ES Turbo
Engine: 2.5L 4 cyl
Planning on doing a full 3" exhaust on the mini tomorrow. No muffler, no cat. Just 3" pipe. I have all the 3" mandrel bends that I'll need, just need to pick up some straight 3" pipe somewhere. I have a couple of questions, though.
How can I get the 2.5" swingvalve to match up to 3" pipe? I know I can cut the 2.5" off the swingvalve and weld 3" to it, but that seems a bit difficult and maybe unnecessary with a mitsu turbo? I can buy an adaptor, 2.5" -> 3" I'm sure at most muffler shops, would I really notice the lack of performance from using a 2.5" swingvalve?
Also, I see a lot of people running side exit exhaust on their minis. Is 3" no cat no muffler going to be too loud to run side exit? I used to run a Z28 with long tube headers, no cat and a hooker muffler, it wasn't too loud.
I've also heard of boost creep using 3" on a mitsu. I plan on upgrading eventually, so I want to do 3" now instead of 2.5" now and redoing it later. Will I experience boost creep? Even with a G-valve boost controller? Any easy fix for it?
Thanks,
Josh
Revdoc is offline
Old 03-02-2004, 02:10 PM   #2
I expanded my 2.5 DP with an exhaust expander then welded it to my 3 inch pipe. As for loud, yeah, I would think a side exit setup would be very loud with no cat or muffler. I am running a cat and muffler and its still fairly loud!
Old 03-02-2004, 09:17 PM   #3
My Ride: No slicks Omni
Drove my van for a week with 3" exhaust no cat/muffler. Only did it because of world record motor swap on a sunday but would not suggest it. Realy hard to sneak up on victoms with the constant whistle of turbo thru resonance of exhaust. Dynomax is strait thru and makes it a LOT quieter.
russ jerome is offline
Old 03-04-2004, 08:52 AM   #4
Engine: 2.5L 4 cyl
Well, it's done. 3" mandrel bent, exits in front of the passenger side rear tire. No muffler or cat. Yes, it is very loud. I can finally hear the turbo whistle. Later I will most likely add a dynomax bullet muffler or something similar.
Revdoc is offline
Old 03-08-2004, 08:22 AM   #5
Revdoc
My Ride: 89 Caravan
How was the power increase? Do you get the boost creep? I bet that thing boosts like a mofo!
I am in the same predicament you were in: want to go 3" and plan tp upgrade but scared of the side effects with the temporary mitsu turbo.
Jeff
My96z is offline
Old 03-08-2004, 03:40 PM   #6
Engine: 2.5L 4 cyl
Well, power increase seemed nice but by that time, I noticed the boost was at 15 psi! Which caused it to hit the boost cutout, which scared the crap out of me and made me think I'd lost a piston. It skipped a tooth on the timing belt also, so I took it apart yesterday to fix that, and it's currently under the knife. So I'll let you know the real power increase when it's running properly.
Also, it does overboost very badly! I had mine set to a perfect 12 psi, and the first time I punched it on the highway it went right past 12 and on to 15. Very bad idea without an intercooler. So you kinda have to keep your foot out of it, it still creeps on me with the grainger set at 9 psi, I'm going to try lowering it later. The real solution will come about via the volvo intercooler in the backseat, as soon as it's on I'll just run whatever the mitsu can put out!
Revdoc is offline
Electricity | Personal Injury Lawyer Los Angeles | Personal Loans | Secured Loans | Mobile Phones
Page generated in 0.60163 seconds with 13 queries
