03-17-2004, 06:19 PM
#17
My Ride: 1987 Shelby GLHS 189
Originally posted by gaboon
I'm bringing LOTS OF BEER
Whooo hooo... Should take a low 12 to make the cut this year... Hoping I'll be ready!!! I know you are already there!!
That header is nice.. How's it hold up on street use...
03-18-2004, 07:07 AM
#20
03-19-2004, 04:41 AM
#24
My Ride: 89 Lebaron GT coupe
Engine: 2.5 T2 turbo, I.C.
Originally posted by ForceFed Wraith
Who ELSE makes a proper header for our cars? I've seen the stock logs from the factory and they're just pathetic, I think headers would show a decent gain per psi, and definitely want to add one while my car is all apart.
ported, the factory manifold works quite well. dont under-estimate them....your money would be better spent on other mods...
headers are some of the most over-rated performance mods out there. not that they dont help, its just that they dont give as much power increase as some believe they do...
but, given the exceptonal power output of Stephane`s car, im sure a header is of much greater benefit to him than most of us...
while that header is a fine piece of work, equal lenght headers generaly give little, if any gains over un equal lenght designs...
03-23-2004, 06:37 AM
#26
My Ride: 1991 Daytona Shelby
Engine: 2.5L
that is actually wrong. equal length header designs when done right allow for higher VE across the board, lower EGT temperatures, and decrease your lag. it allows you to run more hp per pound of boost.
now, what i will say is that the header we see above probably wont be all that much better then the ported out factory. the reason for this is that he air is so unstable through all the bends and because very turbulant at the collector/flange. in order to achieve all that i mentioned, you must keep the bends to a minimum, try to put a straight section before every curve, and most of all, put a straight section between the collector and the flange.
ok, that is quite difficult especially in our cars and motors, so that header is a good accoplishment. the header above will flow way better, however it will only achieve a little less lag.... if i was a betting man.
frank
03-23-2004, 09:38 AM
#27
My Ride: 88 Plymouth Reliant
Engine: 2.5L T2
frank
Hey Frank,
Not to be jerk, but dont those two phrases seem to contradict themselves?
theory, schmeory..... i wanna see dyno results.
Brian
03-23-2004, 11:01 AM
#28
Engine: 2.5L
Brina, (LMAO)
I did screw up on what I was trying to say....
"now, what i will say is that the header we see above probably wont be all that much better in producing horsepower then the ported out factory. "
Remember flow isnt everything. hence why I said, "the header above will flow way better, however it will only achieve a little less lag.... if i was a betting man."
Dyno results would be awesome.
Frank
03-23-2004, 11:05 AM
#29
Engine: 2.5L
Hey Brina, why did you edit your post to say Brian????
03-23-2004, 11:06 AM
#30
Engine: 2.5L T2
so i dont look as retarded as you!
Brian
