Old 04-26-2004, 12:34 PM   #16
3.0Daytona
and boost creep is?
Old 04-26-2004, 12:47 PM   #17
87DTNA
Originally posted by 3.0Daytona
and boost creep is?
The turbine housing is so restrictive the wastegate can not flow enough air. Say your boost controller is set to 12 PSI. Well, at wide open throttle it will probably get to 12 PSI before 3000 RPM, BUT as you are going through the rest of the range the boost starts ''creeping'' up 13, 14, and you will hit boost cutout which is at 15.
Old 04-26-2004, 12:48 PM   #18
and boost creep is?
Do a search on more technical info! But creep is when you driving along at say 12 psi and it goes up all by itself and you can't keep your boost steady. If I remember reading right, this is caused because the turbo is so small, that now you've put on free exhaust, the turbo can't get it out and it stacks up in the compressor and causes boost creep!
Old 04-26-2004, 02:34 PM   #19
My Ride: 89 MR2/93 GrandChero
Engine: 1.6 20v / 5.2 V8
So I'll get creep with 3" out under the door, but what if I run it to the back of the van? Same deal or will that help a little?
aaron7 is offline
Old 04-26-2004, 02:52 PM   #20
Same deal, its not the length, its the size that counts, lol, hahhahahahhahaa
Old 04-26-2004, 03:34 PM   #21
87DTNA
LOL
You'll have creep no matter what if you make your exhaust anything other than stock. Yeah it sucks that much.
Old 04-26-2004, 04:39 PM   #22
So either 2.5 or 3", I won't notice a difference? Might as well do 2.5 and save a buck or two!
aaron7 is offline
Old 04-26-2004, 04:46 PM   #23
87DTNA
It might not creep as fast, but it still will and you with get cutout.
Old 04-26-2004, 04:47 PM   #24
87DTNA
Save yourself a lot of hassle and go with a Turbo 2 garret, with a 2.5'' swingvalve and 3'' exhaust. Your van will be a full second faster in the 1/4 even at the same boost levels.
Old 04-26-2004, 06:02 PM   #25
Wish I had extra $ for that stuff... and the knowledge of where to get it... and how to install it... and tune it... (I'm a Chevy V8 guy, can you tell?)
aaron7 is offline
Old 04-26-2004, 07:38 PM   #26
87DTNA
Save up and do it right the first time. Don't tool around with the mitsu on a 2.5, waste of time and money. Visit www.thedodgegarage.com for more info. I don't think he covers going from a mitsu to a garret, but read up on the basics anyway.
Credit Cards | Credit Cards | Debt Consolidation | Model Ships | Credit Cards
Page generated in 0.43805 seconds with 13 queries
