Old 04-07-2004, 12:04 AM   #1
Installing the 3" SV
My Ride: 2003 Silver SRT-4
Engine: 2.4
Hey guys.. i was just wondering when you install the 3" SV do you have to pull the turbo off, hence the head off.. or can you do this by unbolting the passanger motormount...and jack the motor forward?
FrankNbeans is offline
Old 04-08-2004, 12:10 PM   #2
Engine: 2.4
Awwww
So no one has installed a SV in their car?? I am sure it is no diffrent from installing a 2.5 you one did that.
Old 04-08-2004, 12:17 PM   #3
My Ride: 1987 Shelby GLHS 189
I wouldn't want to try it that way... The old SV bolts are usually very brittle...
glhsken is offline
Old 04-08-2004, 11:37 PM   #4
Engine: 2.4
I just replaced my turbo last yr.. with new bolts...
Old 04-08-2004, 11:49 PM   #5
My Ride: 96 Volvo 850 Turbo
Engine: 2.3l unmolested. yet
have your torch ready (to heat the bolts up) but it shan't be that hard, in the near future I should be doing the same thing.
sethyboy2003 is online now
Old 04-09-2004, 12:27 PM   #6
Engine: 2.4
So i guess it would just be a lot easier to pull the head/turbo off and do it that way?
Old 04-09-2004, 03:27 PM   #7
My Ride: 88 Daytona Shelby Z
I took mine to a shop to do. They did it from the bottom. I was concerned about breaking the bolts myself, plus I was having the new 3" exhaust put on at the same time.
I would do it from under the car, if the exhaust is not there in the way. Even then I would try it that way because if it works out, then you just saved yourself a bunch of time and additional expense.
scott_s is offline
Old 04-10-2004, 12:54 AM   #8
Engine: 2.4
yeah that what i was thinking... since the new turbo got put on the car.. i only drobe it around 2000 miles
Old 04-12-2004, 09:24 PM   #9
My Ride: 92 GTC, S2000, GTP
How much did they charge for the shop? I have 3" exhaust but will put a 3" sv on there eventually because of the leakage.
JandHbodies is offline
Old 04-13-2004, 04:25 PM   #10
My Ride: 1986 GLHS #126
Engine: stock
just when i was gonna start a thread like this i see some of my questions answered.....
so, if i go up from underneath, with all of exhaust removed, can i remove/replace the swing valve w/o any further dismantling of the engine mounts, turbo, etc? can anyone help with that question?
chris at Tu said to soak the crap outa the bolts several times, many days before you begin, using a good penetrating oil.
looking forward to an "easy" install of the TU 3" S.V.
Marcus86GLHS is offline
Old 04-13-2004, 04:41 PM   #11
My Ride: Dodge Spirit R/T
Engine: 2.2L Turbo III
I did it the really easy way. I had Chris install it on the turbocharger I had rebuilt
I can't imaging trying to swap the SV with then turbocharger still on the car. I'm in the middle of replacing the starter on my GLH Turbo right now. It has the 3" SV and downpipe. I'll look at the SV and see if it looks possible from underneath.
iTurbo is offline
Old 04-13-2004, 08:07 PM   #12
Looks to me like it would be possible to change out the SV on the car. The top two bolts could be accessed if you remove the power steering pump and remove those from above. The lower two bolts don't look that hard to get to from underneath; although it might help if the intermediate and axle shafts were out of the way. There is also one bolt inside the SV. I'm not sure how hard that would be to get to.
The 3" TU swingvalve requires special bolts that have a small head. You'll need a special socket.
iTurbo is offline
Old 04-13-2004, 09:31 PM   #13
Chris, what was the measured increases when you had a 2.5" on a 3" exhaust vs. a 3" on a 3"? thanks!
Old 04-14-2004, 02:00 AM   #14
I've taken mine off with it in the car, but this was with the FM header and the bolts weren't too difficult to get out because I put C-5 anti-sieze on them before installing.
Mike B. is offline
Old 04-18-2004, 08:02 PM   #15
My Ride: 84 New Yorker
What modifications have to be done to the wastegate in order for the swingvalve to work?
moparturbo84 is offline
Secured Loans | Loans | Credit Report | Credit Card | Ultimate Credit Card Guide
Page generated in 0.91352 seconds with 13 queries
