04-13-2004, 12:18 PM
My Ride: 1987 Shelby CSX #694
Engine: 1987 2.2L
JB Weld is only as strong as the surface it is mounted to. From your description, it does not sound like it will hold. You would be better off welding something or drilling a hole in the muffer and bolting something to it.
04-13-2004, 01:03 PM
My Ride: turbochrysler.com
On most of the systems I've installed with non-factory mufflers I use a generic hanger that uses a clamp on the end that mounts around the pipe. Usually once the original rubber bracket is removed you can use on of it's bolt holes to hang the universal hanger. I would not trust JB weld to hold an exhaust bracket. If having the factory style hanger is a priority for you I would just have the bracket welded to you muffler, I would guess that your avarage muffler shop would do this for a couple bucks if you don't have access to a welder.
04-13-2004, 02:43 PM
Engine: 1987 2.2L
If you use one of those generic hangers with the rubber straps that has a bunch of holes, you will probably find that it lines up with the back one of the bolts for the bumper strut. I just pop it on there and add a nut to the bolt to hold it on. On the other end you just use a normal U-bolt to attach it to the tail pipe. Worked for me.
On my CSX I welded the stock hanger on the muffler. Unfortunately the Dynomax Super Turbo is much heavier than the stock muffer and the stock rubber mount will stretch. I had to add a couple of springs to it to help it out.
04-13-2004, 04:24 PM
My strap may be in the hole for the bumper mount, not sure, there are plenty of places back there to mount it from what I remember. The universal hangers come in a few designs, some are a long rubber strap that you bolt to the car and a metal ring/u-bolt that connects to the pipe. Others use a metal strap with about 1" of rubber between that and the bracket, these work best for me because they limit the movement of the system, with just the rubber strap my exhaust would rub on the springs when cornering hard, I think the soft factory mount would act the same way.
This is the style hanger I like to use.
http://www.jcwhitney.com/webapp/wcs/...&storeId=10101
04-15-2004, 08:34 PM
#13
My Ride: 1987 Daytona Shelby
Engine: 2.5 16v
I've used that metal weld Epoxy that's a grey putty looking stuff with a black putty stuff on the inside of the grey and it worked good on my friend's turbo laser (DSM) exhaust
