Old 04-16-2004, 01:27 PM   #16
My Ride: 1991 Spirit R/T
Originally posted by ShelbyZTurboII
If it is interchangable w/ this sender, maybe I could just order one...
Yes...as far as the EGTs gauges go, it is interchangeable.
4sfed4 is offline
Old 04-16-2004, 02:27 PM   #17
ShelbyZTurboII
Yea, I just saw how much those senders cost too... I may just plug the hole and sell my EGT gauge... Anyone interested? Never been used
Old 04-17-2004, 11:12 AM   #18
My Ride: 1987 Shelby CSX #694
Engine: 1987 2.2L
Does anyone know what thermocouple type the VDO EGT gauges use? The one they sell is a screw-in type, rather than a compression type. There are only 3 types of thermocouple, but they don't mention what type theirs is.
minimopar is offline
Old 04-17-2004, 11:33 AM   #19
They use the screw-in type and are a pain. I installed mine by buying a compression fitting to shorten the probe a bit because I drilled my hole into the side of runner #4 and it bottomed out. Only good thing about this is that it's easy to get to if I need to change it again.
Christian J. Grest
BUBBA is offline
Old 04-17-2004, 12:31 PM   #20
ShelbyZTurboII
So if I were to get a compression fitting, I should be able to use that w/ my probe to keep it from bottoming out, correct? Where can I find a picture so I can see what type of fitting this is and also, where can I get one?
Old 04-17-2004, 02:48 PM   #21
Engine: 1987 2.2L
Ooops...when I said type, I meant the thermocouple itself. There are a few different types. For instance, the Autometer gauges use K-type thermocouples. I'd like to just buy the VDO gauge and get a better thermocouple for it.
Old 04-19-2004, 11:13 AM   #22
Engine: 1987 2.2L
Just in case anyone cares, I did some research. Information on VDO gauges is always scarce, but after reading a bunch of truck forums, I am fairly certain that VDO uses the defacto-standard K-type thermocouple (VDO likes to be weird, so I wanted to make sure). This means I can go with an autometer compression-type thermocouple and get the plain VDO gauge. Sweet.
So do most folks put the probe on the underside of the #3 runner, or more towards the turbo at the collector?
It seems like people go with the more expensive ATM-5244 kit. This is for the narrower probe, correct?
Old 04-20-2004, 10:24 AM   #23
ShelbyZTurboII
most people that i've talked to install it in the number 4 runner, several inches down from the head. i talked to gary donovan about this as well and that is what he recommends for a good reading as well. the reason most people don't install it after the turbo is that the exhaust gas will get heated up through the turbo and you will get a fairly inacurate reading of the temps. inside your engine. I would recommend doing what 'the s is silent' did and go up from the bottom of the runner, straight up. that is probably one of the best intstallations i've heard this far.
Advertising | Free Ringtones | Bad Credit Loans | Bankruptcy | Mortgage calculator
Page generated in 0.65403 seconds with 14 queries
