04-26-2004, 02:53 PM
My Ride: 85 GLHT, 87 ShelbyZ
Originally posted by WantSum?
Actully the car will be registered in ohio at my parents. They have emmissions, but only like every 2-3 years, no inspections. so for me no cat, no problem. here is what i want to know.
I have the 2.25 SV so i can only run a 2.25 exhaust.
1. If i get a mandrel bent exhaust in 2.25" with no cat and a glass pack what will i be looking at gain wise?
VS.
2. changing the SV out for a larger one and go with a bigger exhaust, same set up.
3. how hard is it to change the SV? what do you do?
4. what SV would i use?
Here is the basic set-up
T1 5 speed completely stock except for
very soon to be large IC
mangnacore wires, good plugs
45k coil
nate
Because you run the 2.25" SV doesn't mean you can't run big exhaust. Here's what you do. You call cindy at FWDP and tell her you want the 3" JRB style downpipe, and the 3" catback setup for your car. You then go down to the j-yard and get yourself a 2.5" donut/downpipe from a 89+ mitsu turbo car (you only need about 6" of the downpipe). Now when your downpipe arrives from FWDP you take your 2.5" donut and pipe and the 3" d'pipe to the exhaust shop and have them flare it out immediately after the flange that holds the donut up in the sv so that it just slides down into the 3" pipe. The sooner you flare it the better. I leave just enough so that I can barely spin the flange. Then I take it home and align the downpipe in the tunnel and then cut the 2.5" setup as short as I can and still have it sit in the 3" d'pipe enough to weld it up. After it's welded I then notch the flange towards the donut so that it'll fit the smaller flange diameter of the bolt pattern. Then you can bolt up the 2.5" donut to the 2.25" SV. Works pretty good. Then if you upgrade later you're still ok. If you go all the way to a 3" SV you'll have to buy a matching downpipe with a 3" donut or an adapter through TU depending on your budget. But you can have 3" exhaust on a 2.25" sV. I ran 13's on my heavy daytona with a mix of 2.5 and 2.25" side exit like 87DTNA described above. But I did pick up some lower end torque and a bit of top end going to the 3" setup I just described. Worth it if you're gonna go straight from stock to 3". I have since upgraded to a ported 2.5" turbonetics SV and then switched to a 3" donut with it's matching downpipe from TU and sold the old d'pipe with the 2.5" donut. Going to the 3" donut did help with boost spool and cruising vacuum. But it's not a real huge gain. Anyway those are your options. By the time you get to a larger SV and a 3" donut you should have converted your car to T2 along with added some beefier rods at the least if not gone all the way with a commonblock T2 shortblock.
04-26-2004, 03:34 PM
My Ride: '88 Shadow ES 16v
Engine: 2.2 T-III
Originally posted by hiboost
if i was you i would go 3 inch....
3" is nice, but it's louder and more expensive. 2.5" mandrel bent is more then enough for a stout street car, especially if it's running the stock Garrett with a .48 exhaust housing. The housing is a cork long before the exhaust system is.
04-26-2004, 07:29 PM
#12
I went from 2.5" straight pipe, to 3" with a dynomax Race mag. Pipe lengths stayed the same. The 2.5" was much louder. I am now running 3" straight pipe in the same configuration as the other two. I find it the same volume as the 3" with the dynomax. At idle I can't tell if it's running sometimes. Just a nice deep burble. The 2.5" was like a gun going off all the time. I didn't like it all the time it was too loud and sharp.
Also I picked up a good amount of low end grunt going to 3". With the 2.5" I could go from about 10MPH in 2nd and floor it. The tires would be right at their breaking loose point but not cross it. Going to the 3" crossed that point by a big margin. Doing that would result in lots of wheelspin  The 1st two systems (2.5" and 1st generation of 3") were with the .48 stock 87 T2 turbo. Going to the 3" was definately worth it and netted a gain in performance.
If you have a garrett "Get Real" Get 3" from the beginning. Why spend the cash twice? I believe in the Do it once, do it right philosophy. Plan for future mods. It ALWAYS saves money in the long run.
I know someone that had a 3" SV and 3" side exit on a T1 GLH with just a grainger. The Car absolutely screamed for what it had into it. 2.5" exhaust should of (and most of the system was) stock for our cars. 3" is just the next step up. Remember the little tiny sections of 2" and 1 7/8" pipe were from N/A versions of our cars. SAD! But Mopar had to save money somewhere.
Now People see me with the oddball stock 2.5 in a 3120lb car that runs 13.8's@101.8 on street tires (2.360ft) and 13.5psi with 5700rpm shift points. So your results may very.
04-26-2004, 07:32 PM
#13
Originally posted by 87DTNA
GLHNSLHT2-
Thats an interesting idea.
Well, I have a 2.5'' mitsu swingvalve for sale if he's interested in doing that!
NO, you just use the 2.5" donut and downpipe from the 89+ mitsu car. Any 89+ turbo actually but Mitsu ones are the most common so I said that. A Mitsu SV will not work on his garrett.
04-26-2004, 07:48 PM
#15
Oh I must have not understood what you were trying to say then. I thought you were taking the large flange off a mitsu SV and welding it onto a garret 2.25'' SV. I know that they do not interchange, garret has 5 bolts mitsu has 4. Plus the garrets wastegate flapper is on the SV, the mitsu has the flapper in the turbine housing.
Nope, you weld the 2.5" donut and pipe into the JRB style 3" d'pipe. The Flange I was referring too is the stamped piece of steel that holds the downpipe to the SV.
