05-08-2004, 06:18 PM
Egt probe help?!
I got an EGT probe from aircraft spruce, it says it's a 1/8 NPT. Does 1/8 NPT only have 1/8 interior diameter???
It came with a fitting with two male threaded ends. One end is about 1/4inch, this is where the probe goes on, the other end goes to the exhaust manifold and is a little less than 3/8inch.
I went to OSH and I couldn't find anything that fit it (i looked for nuts so I knew what the thread size/type was)
I'm really confused now as to what tap to use on my exhaust manifold. The only thing on the fitting that is 1/8 is the interior of the exhaust manifold side (the threads are about 3/8)
