Old 06-20-2004, 06:04 PM   #1
need help right now!!!!
My Ride: 87 Daytona Shelby Z
how can i get the exhaust bolt off on the side of the turbo on the S/V? I got the outside one off...using 2 rachets...but the inside one has no space to put anything in there to break it free....I cant even fit a regular wrench in there....please...I wanna get this done soon......thanks.
Timby101 is offline
Old 06-20-2004, 06:11 PM   #2
My Ride: 86 GLHS 488
Engine: 2.2 T2
The nut on that one should have a little plate welded to it. So you should only have to turn the bolt end. If it's hard to start then spay it w/ your favorite rust remover. You have to be careful not to break that little plate off.
If you do break it off and it just spins then you can try using a flathead or something similar wedged up in there to hold it in place while you back the bolt out. And if all else fails an angle grinder can fit up in there if you're careful, or work at it with one of those little hacksaws.
I've had to grind/hack one of those off before myself... not fun. Well at least not after the first hour...
Sergio Diaz III
86 GLHS 488
88 Subaru Justy GL/RS
sergio is offline
Old 06-20-2004, 06:14 PM   #3
didnt see any plate and it was spinning quite freely...lol....but the flathead is a great Idea...im gonna go try that now...thanks bunches....any other info would still be wolcome....:-D
Timby101 is offline
Old 06-20-2004, 08:02 PM   #4
well after lots of trying...i did find a way to get a 1/2" wrench in there....took about 2 mins after that.......woulda been nice about 3 hours earlier...thanks tho.......
Timby101 is offline
Page generated in 0.14128 seconds with 11 queries
