04-27-2008, 10:25 AM
Re: Vacuum Lines missing...85' Daytona turbo
The hard plastic lines and vacuum harness is not available, you are going to have to start from scratch.You may want to check a local junk yard and rip the vacuum lines off another vehicle so you have something to start with.You also need the restictors and check valves.
Unfortunatly this is a time consuming process and will require a lot of patience.
You have to go to your local parts supplier and get vacuum tees/connectors, and assorted vacuum line and just start to route the lines.You may be able to get the check valves there also.
If you have a Pep Boys in your area they will have a complete selection of vacuum line and connectors, better than Auto Zone/Advanced Auto.
Do not use washer hose, it is too thin and will collapse, use a high quality, thick walled vacuum line.
I am sure somebody else that has done this will chime in and have some better ideas or another source to get what you need.
Good Luck with the project, any questions do not hesitate to ask.
