Old 05-21-2008, 08:20 AM   #1
i hate the RFL!
My Ride: 88 shadow
got the stage 3 computer from cindy running 15 psi. when i would hit full boost, the BOV would crack open and it'd be a huge bost leak. so i threw some quarters in it (couldnt find the washers) i ended up with the 2 washers that were in it before, plus $1.50 in quarters... it holds fine now at WOT but when im driving it regularly around town, im getting insane compressor surge every time i shift cuz the spring is too stiff to release around 5-8psi. im guessing its just because its a piston type BOV? are the others (greddy type S/RS or HKS super sequential) any better in different boost situations? arethose still piston type? if not, how do they work?
88shadowpjct is offline
Old 05-21-2008, 08:22 AM   #2
Re: i hate the RFL!
Resident piston cracker
crazymadbastard's Avatar
My Ride: 92gtc vert
Engine: 2.5 8v
Feedback: (20)
where is the vacuum source for the bov?
Come for a dyno run NEW Get-together 2-23-2008 @ 10am
http://www.turbododge.com/forums/f1/...-dyno-day.html
crazymadbastard is offline
Old 05-21-2008, 08:42 AM   #3
Re: i hate the RFL!
My Ride: 89Daytona/99Mustang
Engine: 2.2L Turbo II/3.8 V6
get a 1g DSM BOV and call it a day($30). will easily hold up to 30psi and since its factory it opens at low and high boost. Never had a leak problem, try placing the T for the vaccume source before the check valve on the TB. This will allow the boost to hold it closed along with the spring. (this is where mine is located)
scorpion1 is offline
Old 05-21-2008, 09:46 AM   #4
Re: i hate the RFL!
SHELBY 16V !!!
lotashelbys's Avatar
My Ride: Lots of TIII cars:-)
Engine: 16V TIII
Feedback: (17)
Images: 1
I have REAL RFLs on 4 of my cars and everyone works perfectly at any amount of boost. I found out that if you hook the vacuum source to the port on the TB you get the fastest responce without any surge before it opens. I have no washers in in any of them either. Try that and see how it works
~Jackson~
TIII GURU
91 Spirit R/T
91 Spirit R/T(GFs hotrod)
lotashelbys is offline
Old 05-21-2008, 11:03 AM   #5
Re: i hate the RFL!
My Ride: TIII R/T
Engine: 2.2L TURBO III
Feedback: (9)
i have a few washers in my Turbo XS RFL, still no real problem with venting
xtrempickup is offline
Old 05-21-2008, 12:24 PM   #6
Re: i hate the RFL!
My Ride: 2.4 Turbo Spirit
Engine: 2.4 DOHC
Going to try that on my knock off RFL, Thanks
speeduphoria is offline
Old 05-21-2008, 12:35 PM   #7
Re: i hate the RFL!
My Ride: 88 shadow
mine is real. its a turboXS.
i had it hooked up to the port on the TB, brake booster, and straight form the manifold. same problem at every point.
about the DSM one... i was thinking about trying a VW one off a 01 jetta wolfsburg. my buddy put a hybrid on his car and has the stock one sitting around. same thing right? he ran the APR tuning it was running 20psi spike and holding 18
Old 05-21-2008, 07:54 PM   #8
Re: i hate the RFL!
My Ride: '87 Daytona Shelby Z
Engine: 2.2l TII
Images: 3
I used RTV around the lip of the piston on mine, I've had it up to 16psi while boost testing and it doesn't leak, I only had 2 washers in it. Its also hooked into my vacuum manifold
impuresoul2k3 is offline
Old 05-21-2008, 08:43 PM   #9
Re: i hate the RFL!
about the DSM one... i was thinking about trying a VW one off a 01 jetta wolfsburg. my buddy put a hybrid on his car and has the stock one sitting around. same thing right? he ran the APR tuning it was running 20psi spike and holding 18[/quote]
I dont know much about VW's so I couldnt really tell ya. For the price there worth it to me though (1g DSM BOV's) I even have a spare layin around in case something does happen...still waiting for that day lol Ebay for them. Dirt cheap.
Old 06-30-2008, 06:37 AM   #10
Re: i hate the RFL!
My Ride: '84 GLH, '04 R/T
Engine: 2.2 HO, 2.0 Magnum
Ive never had a problem or had to use washers on a real RFL and Ive had 3 of them!
vntned is offline
Old 06-30-2008, 09:34 AM   #11
Re: i hate the RFL!
My Ride: 1985 Dodge Omni GLH
Engine: 2.5 swap
I also have never had problems, mine is hooked to a vac nipple in the top of the TB.
stargazer7467 is offline
Debt Loans | Car Insurance | Remortgages | Buy PSP | Cell Phones
Page generated in 0.54807 seconds with 13 queries
