Old 06-28-2008, 02:48 PM   #1
Intercooler hoses blowing apart
My Ride: 86 GLHT
Engine: 2.5 CB
86 GLHT with 2.5, t3/t4, custom cal, 3" exhaust, and dual stock intercoolers. I am trying to run 20-22 lbs. of boost but under WOT the lower intercooler hose blows apart the joint between the compressor outlet and the intercoolers. I have a BOV on the lower line and am using the good t-bar clamps but it seems like there is a big restriction of flow going into the engine and at 20lb. the pressure blows the line apart.
Anyone have a suggestion short of welding a steel line w/o any joints in place? The car pulls hard but blows the joint apart about 3/4's down the track and whenever I hold the boost at 20 for a few seconds.
I posted pictures and it is the joint in the back that comes apart most of the time.
MOPARMANIAC
shelbymaniac is offline
Old 06-28-2008, 02:54 PM   #2
Re: Intercooler hoses blowing apart
My Ride: 95 Caravan
That connector isn't ribbed. that smooth tube allows the hose to just slide off. If it had a slight flare at the ends, it would be able to hang on better.
turbo1168 is offline
Old 06-28-2008, 03:00 PM   #3
My Ride: 1985 &86 Omni glhts'
Engine: 2.5 T2
Images: 14
Ditto. Also appears to be a bit too short, but mainly it's the lack of a bead on the pipe that allows it to come out of the coupling. What material did you use to plumb the ICs' with?
ol"blue is offline
Old 06-28-2008, 03:17 PM   #4
My Ride: 85 GLHT, 87 ShelbyZ
motor movement pulling it off? Is that hump hose there?
GLHNSLHT2 is online now
Old 06-28-2008, 04:11 PM   #5
My Ride: SOLD!
Get a longer piece of tubing right there and to make it even more solid, use a hump hose to allow for any slight misalignments or line movements. I have ran a turbo setup both ways. One with out the beads on the ends of each IC tube and one setup with no beads, & with straight polished smooth tubing.
No problems either way.
Gutfeeling is online now
Old 06-28-2008, 04:31 PM   #6
Smile Re: Intercooler hoses blowing apart
My Ride: 86 GLHT
Engine: 2.5 CB
I have PVC pipe for plumbing the 2 stock intercoolers together. The joints are all glued and they work great. I will try and flare the end of the piece of steel pipe where the joint goes together9or get a longer piece) and see if that holds it. I don't think it is the motor moving and pulling it apart as it is an automatic and doesn't move very much with the mp mounts installed.
Thanks for the suggestions.
MOPARMANIAC
Old 06-28-2008, 05:24 PM   #7
My Ride: 1991 Shelby Daytona
Engine: 2.5L T2
true but you cant see the engine when ur driving so it can totally torque and pull that tube out ive had it happen had to put a longer pipe on it, though u defnitly have to have ribbed ends specially when running higher psi
91shelby is offline
Old 06-28-2008, 05:40 PM   #8
TurboDodge.com Admin
moparfwdsleeper's Avatar
My Ride: 87 CSX
Engine: 2.2TII
Feedback: (30)
Images: 166
JB Weld - Bead
Clamps - T-bolt style
-Clayton ~ Forum Admin
Home of the Original Turbo Dodge Forum
1987 Shelby CSX #674!
moparfwdsleeper is offline
Old 06-29-2008, 11:01 AM   #9
Theres no reason that should be coming apart with the t-bolt clamps on it, even without a bead. you either arent getting the clamps tight enough, or the pipe is too short.
xrattiracer is offline
Old 06-29-2008, 11:22 AM   #10
My Ride: 91 Spirit R/T,
Engine: 2.2 TIII
Feedback: (6)
simple old solution = spray pipe with hairspray before tightening. The hair spray is wet (duh) and acts like a lubricant to ease getting the pipe on and then dries sticky and holds the rubber. Got a GF?
rx2mazda is offline
Old 06-29-2008, 11:33 AM   #11
My Ride: 2.4 Turbo Spirit
Engine: 2.4 DOHC
or spray paint works also
speeduphoria is offline
Old 06-29-2008, 12:09 PM   #12
My Ride: 86 Laser XT
Engine: 2.2 turbo
Images: 2
Hell i should do that.
Though I think my gf would kill me for using her hairspray.
She has to have all the expensive shit...
1986 Laser xt t1 5 speed sunroof-BUY IT AS WELL!
89 Lebaron GTC Convertible t1 auto- BUY IT PLEASE
Need a set of wagon wheels???- http://www.turbododge.com/forums/f7/...on-wheels.html
Old 06-29-2008, 12:42 PM   #13
Engine: 2.2 TIII
Feedback: (6)
What
Spray paint? I take it your joking, right? If not, save the spray paint for your ride
rx2mazda is offline
Old 06-29-2008, 12:43 PM   #14
Engine: 2.2 TIII
Feedback: (6)
GROW A PAIR
rx2mazda is offline
Old 06-29-2008, 01:56 PM   #15
My Ride: 89 omni & 90 T1 shad
Engine: 2.5L HX-35 w/alcohol
those look like cylicone couplers. take some alcohol like brake cleaner and spray or dump a bit on the pipe and coupler then quickly before it dries up, tighten the joint together. youll have to peel it appart with a screwdriver after that!! works great!
turbo minivan is offline
