Old 07-04-2008, 10:08 PM   #1
Valve work *PICS*
My Ride: 96 neon
Engine: 2.0L
Jack's Dodge is offline
Old 07-05-2008, 12:27 AM   #2
Re: Valve work *PICS*
My Ride: Neons + Caravan
Engine: 2.5T
info? How was it done?
Looks awesome though!
NoDestiny is offline
Old 07-05-2008, 02:00 AM   #3
TurboDodge.com Admin
moparfwdsleeper's Avatar
My Ride: 87 CSX
Engine: 2.2TII
Feedback: (30)
Images: 166
did you use a drill press?
-Clayton ~ Forum Admin
Home of the Original Turbo Dodge Forum
1987 Shelby CSX #674
1985 Dodge Omni GLH - Parting Out, PM me!
moparfwdsleeper is offline
Old 07-05-2008, 09:41 PM   #4
My Ride: 96 neon
Engine: 2.0L
Just use my work drill and some sand paper. 60 grit coarse and 120 fine. Going to hit them again using 60, 100, 180 and see how that turns out. Have to get a table vice to finish them The end result looks like this:
Have a read: Turbo Build-Up — Mike Holler and Bob O’Neill discuss Chrysler turbochargers
*EDIT* Just did a valve using the 60, 100,180 and this worked much better than just the 60 and 120. Also added a dab of silicone grease to keep the friction down some. The valve heats up fast at those speeds. Gloves ftw.
Old 07-06-2008, 10:16 AM   #5
The Pope's Avatar
That was a lame artical that doesn't go anywhere. Why not just come right out and say what you need to make 30 MPG? Why discuss the theory of how to do it. I got lost just trying to read it. You first describe how the computer works in closed loop in the first place. Then you describe how to make the computer do its job better. That's it. 200 + HP and 30 + MPG? Really easy, stone stock 89 T2 setup with just a FWD stage 3 computer. Leave it stock and live with just what the computer gives you. Make sure the engine has great, compression, vac lines and sensors / connections. The WHOLE artical could have been wrote in one sentence really
As far as the valve thread. I think you guys should just buy a good set of +1 SS valves. The polishing effect is going to go away once the carbon and fuel and heat hit the stock valves, the crud will return. Other than making the valve smooth there is a issue of having a better shaped valve. So with this you get the polish, but your still missing better shape and material. Just looks like to much work per gain. Like walking your date to the front door, giving her a small kiss and walking off without trying anything else. Too much work when all you want is first base?
Rob Walsh
84 DC Shelby Rampage
86 GLHS 76
87 GLHS 306
89 CSX 187
89 turbo mini
70 R/T SE Challenger
The Pope is offline
Old 07-06-2008, 11:24 PM   #6
My Ride: 96 neon
Engine: 2.0L
I drive a neon. I get 38+ mpg's stock running low 14's. Yes it's modded.
What difference do stainless steel valves make? Proof? Polishing reducing the chance of detonation, as the pits in the "stock" valves are smoothed out so the remains from combustion are less likely to stick to a smoother surface. Rain-X style. Also, this process took about 3 minutes per valve, and $13 in sand paper. How much is involved with the Stage 3 pcm on a stock T2 that is in great shape from the start? This is 2008 making the 89 19yrs old. Yeah they are out there. Way out there.
Polishing is only part of the process. This is the end result:
Old 07-06-2008, 11:54 PM   #7
My Ride: 87 shelby z daytona
Engine: 2.257L t2
no fare, my neon gets 16-18mpg... and is a dog lol.
TurboDoctah is offline
Old 07-07-2008, 07:59 AM   #8
My Ride: 96 neon
Engine: 2.0L
Yikes! Check codes, give it a tune up, get new O2 sensors, check tire pressure and tread, and see where that lands you. Also is your car an mtx or atx?
Old 07-12-2008, 09:37 PM   #9
My Ride: 2005 Dodge SRT-4 ACR
Engine: 2.4L DOHC Turbo
Prepping Valves for Performance
rich tideswell is offline
Old 07-12-2008, 09:59 PM   #10
My Ride: 96 neon
Engine: 2.0L
You going to do it or what?
Old 07-12-2008, 10:58 PM   #11
My Ride: 96 neon
Engine: 2.0L
Old 07-14-2008, 04:58 PM   #12
My Ride: 96 neon
Engine: 2.0L
Old 07-27-2008, 03:28 PM   #13
My Ride: Dodge viper
oh wow much better
teenleadership is offline
Magazine Subscriptions | Buy PSP | Credit Cards | Mobile Phones | Mortgage Calculator
Page generated in 0.53516 seconds with 13 queries
