Old 08-07-2008, 10:31 PM   #1
My $0.02 vacuum block
My Ride: 88J 94P 03dime
Engine: 2.2 in all of em
got bored today, was wanting to redo vacuum lines.
after installing new injectors, fuel rail etc , i had this extra fuel rail laying around. got a brainstorm to cut it up and make a vacuum block out of it.
first i cut the rail in half next to the schrader valve. then left it about 3 inches or so long, so that i had one stand for a fuel injector, the schrader and just straight tube. drilled 4 holes in it- one for each vacuum supply- map, FPR, boost gauge and EVAP. kinda looks like a flute at this point.
then i took 2 pennies and soldered them onto the ends to seal it up. worked pretty well.
for vacuum nipples, i had a 20 pack of MIG welder tips. i dont wear them out enough to worry about having that many, so i took 4 and chucked em up in a drill and used a file to give them a ridge to prevent blowing the hoses off under boost. soldered those into place
for the main vacuum input, i just used some left over 5/16 fuel line and a fitting, soldered those into the injector stand on the tube. hooked it all up with silicone hose and rubber elbows.
looks decent, a lot better than the tangled mess that was there before. the vacuum tube would look a lot better if i had used a drill press and took my time making sure the holes for the vacuum nipples were straight, but otherwise it turned out good and works like a champ. and if i decide i need more vacuum ports all i gotta do is drill more holes and add more nipples.
basically just made this out of trash and 2 pennies. my .02 to add to the community! lol
crusty shadow is offline
Old 08-17-2008, 08:18 AM   #2
Re: My $0.02 vacuum block
My Ride: OMNI/ShelDak/TSi/SL
Engine: 2.2 'GLHS style' TII
Feedback: (36)
awesum TD ingenuity ! way to add your $0.02 %)
I like the AFPR too ...
detobias is offline
Old 08-17-2008, 11:17 AM   #3
My Ride: 89+90 Daytona Shelby
Engine: 2.2 TII, 2.5 TI
Images: 12
ROFL. That's awesome! Another perfect example of the thrifty but creative abilities of the TD community.
I hope nobody from the government sees this. Isn't it a crime to destroy money?
EvilcowRoland is offline
Old 08-30-2008, 08:06 AM   #4
Garrett Booster
79Colt's Avatar
My Ride: 1979 Colt
Engine: 1.6L
Good job,
I would never thought about the MIG welding tips!
Andres
79Colt is offline
Homeowner Loans | Comprar piso en Denia | Loans | MPAA | Charity
Page generated in 0.32212 seconds with 14 queries
