07-01-2009, 11:52 AM
Re: 2.2L N/A '84 camshaft lubrication
My Ride: 1984 Reliant SE
Engine: 2.2L N/A
Would I be causing myself more trouble than it is worth to pull the bearing caps on the two end lobes and check to see if there is any lube in the bearing surface? The Autozone help diagram shows to remove the cap bolts in this order (front-back 1,2 on the cam gear end and back-front 3,4 on the back end). I realize that I will be disturbing the seals that I installed.
On further review, I checked the help diagram again and---lo and behold---installation torque sequence is the REVERSE of removal sequence and this means that I can just pull the center (#3) cap and inspect for journal pre-lubricant). This will not disturb the seals and if it is dry in there, I will call the machinist and give him a chance to respond as to why or as to his experience with pre-lubing these cams. And I can just bite the bullet and remove the cam and do it right myself.
The point is that the front and rear cap bolts of #3 are the last to come of when removing since one starts from the ends of the camshaft (sprocket and then the back) and works in to the center cap. This ought to put this thread to rest. Call it kindergarten camshafts. :)
