09-22-2004, 03:45 PM
#31
My Ride: 94 Ford Lightning
Engine: 351W v8
I think you'll find, once you install the vacuum block, that you'll actually have too many ports. Drilling into your manifold is also uneccesary, as there are already several ports available.
I used a few brass fittings and mine hangs right above the fuel rail in the middle of the intake. If you want, you can run a vac tube from that big ass port above the knock sensor on the front to the firewall and mount in there. Just whatever you think looks peachy.
I remember, before I installed my vacuum block back in the day, that i was scared of the vacuum system. Oh, the mystery. Now it's just plug and play. You make sure you have a good vac source (either booster nipple on back of intake or main nipple on front, somehow connect it to the block, then just run lines to anything that requires vacuum. End of story. No need to second guess yourself. If you forget to hook something up, it just won't work. Forget to hook up the bov, and you have no bov, forget to hook up the FPR, you get no fuel. Forget to hook up the map, you got no start.
If you forget something, just hook it up...easy as pie!
d
