Old 07-27-2005, 10:53 PM   #16
My Ride: 87 Shelby Lancer
Engine: 16v 2.2
Simon, you said in the linked post that your car, or van as the case maybe , ran leaner with out it. Hows does that happen when its only sucking fumes just above idle, anything past that you should be building boost and closing the check valve?
itoktoeatfish is offline
Old 07-28-2005, 02:00 AM   #17
When your cruising, your in vacuum so yes, your pulling vapours out of the cannister. I can't explain it, I was going to Portland and had just got my egt guage. I noted my temp for a while then pulled over, disconnected and plugged the purge lines and started driving, went up aprox 500 deg from before at exactly the same speed!
Credit Cards | Looking for Credit Cards? | Debt Consolidation | Web Advertising | Verizon Ringtones
Page generated in 0.51887 seconds with 13 queries
