Old 07-24-2005, 01:57 PM   #1
More TBI cam info. needed
My Ride: 89 Spirit ES
Engine: 2.5 STD TII 20psi
At SDAC a guy named Paul (he had the dark blue mini van with the custom intake and 4" exhaust) said that the 94 TBI cam made more power than all other TBI cams due to more duration. What are your thoughts on this?
And if I decide to go out to the junkyard and pull out a TBI cam, it's just a bolt in procedure, right? No replacing any parts or anything?
Also when installing the cam sprocket to the cam how do I know exactly how the sprocket goes onto the cam, for timing's sake?
Dave is offline
Old 07-24-2005, 02:15 PM   #2
My Ride: GLH-T
Well since you have the round tooth sprocket,its not going to be offset at all. Like mine would be if i used a 89 or higher tbi cam. I went with the '88 tbi because it was roller and it was square tooth..but to answer your question, you dont have to modify anything .Just match up the sprocket with the keyslot and your golden...
P.S. Make sure the head that your pulling the cam from doenst have "OSJ" stamped on the drivers side...if you put that cam in, you will loose major oil pressure
87DANCEonYOU is offline
Old 07-24-2005, 03:18 PM   #3
My Ride: 94 shadow base coupe
Engine: 2.5 TBI
TBI cams benefit turbo motors?
bluneon is offline
Old 07-26-2005, 10:46 PM   #4
Yep.
By the way, Ill talk to you about the cam more tomorrow.
Dave is offline
Old 07-26-2005, 10:52 PM   #5
Yep, see the sticky at the top of this forum-
http://www.turbododge.com/forums/showthread.php?t=68064
Cheap Loan | Car Loan | Web Advertising | Mortgage Loans | Debt Consolidation
Page generated in 0.50212 seconds with 13 queries
