Old 07-27-2005, 09:01 PM   #1
Charge air temp sensor - installing
Swapping my '87 Lebaron to an '88 2.2 Turbo I engine.
I was just curious about the air temp sensor that goes into the intake. Does it NEED to be in the intake or can I say, drill a hole in my air box and install it on there?
I'm just curious about this sensor. Is it for detecting ambient air temp or the temperature of the air under boost?
If it's just for detecting ambient air, putting it on my air box shouldn't be a problem, right?
TurboBaron is offline
Old 07-27-2005, 10:56 PM   #2
Resident piston cracker
crazymadbastard's Avatar
My Ride: 92gtc vert
Engine: 2.5 8v
Feedback: (22)
Charge air is for under boost. After the air goes trough the turbo and gets compressed
and gets hotter. The computer looks at the boost pressure and the temp to compensate with fuel. SO, yes it needs to be in the manifold or just before the throttle
body.
dyno sheet
fmic install:
crazymadbastard is offline
Old 07-27-2005, 11:42 PM   #3
while the topic is up, though, you don't have to go nuts to get it into the intake. just unscrew one of the vacuum source nipples on the front of the intake, and thread the sensor in. same thread diameter and pitch. run your vac lines to the other nipple and call it a day.
tony
macncheese is offline
Old 07-28-2005, 12:16 AM   #4
That sounds like a good idea. I'll see if there are any other provisions on the intake!
Just for giggles though, anybody know what size thread to make the hole on the intake for the sensor?
Old 07-28-2005, 02:39 AM   #5
there are three vac nipples. the one on the back that runs to the brake booster, one on the front near the middle, and one on the front near the bottom. drill away only if you find it entertaining!!!
tony
Old 07-28-2005, 02:46 AM   #6
DocFish's Avatar
My Ride: '89 Mini
Engine: 2.5 common
Theoretical question. If you run the charge air temp sensor in the airbox, it'll make it run fatter, wouldn't it? Be enough for an extra pound of boost?
DocFish is offline
Old 07-28-2005, 10:26 AM   #7
i suppose it would, since it'd be seeing a cooler charge. but for that matter, why go through the bother of drilling your airbox? since you're adding wire anyway, just run it to the nose cone. oh yeah, and assume responsibility for it because i've never tried!!!
tony
Old 07-28-2005, 10:36 AM   #8
DocFish's Avatar
My Ride: '89 Mini
Engine: 2.5 common
Already did Tony. Swapped from a 2-piece to a 1-piece that didn't have provisions, so I just layed the sensor and wiring up on the cowl. No codes, no harm done.
DocFish is offline
Old 07-28-2005, 01:34 PM   #9
I guess that would work, for a more performance minded person. Make the computer detect cooler air than it should and it fattens up the mixture. I could see how that would be a good idea. I'm poor though, I'm aiming more for the 30mpg aspect of the car. hehe
Old 07-29-2005, 01:47 AM   #10
heh, even NOT being poor might make us aim for the 30mpg, because otherwise, the price of gas could MAKE us poor!
tony
Mortgage Loans | Online Image Resizer | Credit Cards | Debt Consolidation | Refinance
Page generated in 0.66288 seconds with 13 queries
