07-29-2005, 08:41 PM
boosting change
Originally Posted by turbovanman
Sensors do indeed swap over!
Also, depending on what model you got it from, you might have to swap over the actuating arm also, if its bolted on!
the AIS is different between them, the 52 tb has a larger hole and larger AIS plug. I just use the sensor on the 52. Some arms work, others need swapping. Also this is a waste of time if the neck of you intake is smaller than 52mm. The 1 piece intake for instance has a tiny neck and the 52 is bigger. The 2 piece intake gets larger after the tb, so porting it larger and using a 52 works great. Other option is modding a 1 piece or custom intake.
