10-10-2005, 12:41 AM
TEO4H information
Here's some info I came across while surfing other turbo boards
"Output numbers for the TEO4H are as follows: 360 cfm (34lbs/hr) at 15psi/170deg charge temp (no intercooler)reaches those specs at 3200rpm on a simulated 1.6 ltr engine. Factory wastegate set at 9psi/direct port referance. Max HP within the effeciency envelope appears to be 230 HP (very conservative figure)The Teo4h has a very small hot side a/r .38 and is therefore suited best to small displacment powerplants. A CA16E or CA18E would be ideal for application of this turbocharger."
it was on a nissan board.
DRAVEN
