Old 10-16-2005, 09:09 PM   #1
Blow off valve venting at idle
My Ride: 89 Lebaron TII convt
Engine: 2.2 turbo II
i put an intercooler on my 88 lebaron gts 2.2 turbo auto, and i moved the BOV to the outside and mounted it on the t2 airbox. is it suppose to vent air out at idle. all of the vacuum lines are hooked up right? because if it does, how would my car boost, if air was going out?
Beachbum3478 is offline
Old 10-16-2005, 09:13 PM   #2
DocFish's Avatar
My Ride: '89 Mini
Engine: 2.5 common
Normal condition. At idle, the high vacuum is pulling up on the valve, allowing air to pass through. Under boost the valve will be closed due to spring pressure.
DocFish is offline
Old 10-16-2005, 09:41 PM   #3
My Ride: 87 Z
Engine: 2.2 (+.040)
If it bothers you that much, you can (depending on which BOV you're using) add a shim washer or adjust the spring tension on it. It'll affect how fast/far it opens when it vents though.
87shelbyt2 is offline
Old 10-16-2005, 10:29 PM   #4
My Ride: lebaron turbo
Engine: 2.2 turbo
Its normal my bov does the samething and i like it makes the car sound mean.
turbo88
Turbo88 is offline
Old 10-16-2005, 11:05 PM   #5
My Ride: 85 GLHT, 87 ShelbyZ
Just filter it
GLHNSLHT2 is offline
Internet Advertising | Hotel Portal France, Italy, UK | Credit Card Consolidation | Photoshop Tutorials | Loans
Page generated in 2.06176 seconds with 13 queries
