10-31-2005, 02:14 AM
Originally Posted by WHIPAV8
NPR I/C, 3" Exhaust, Highly ported. All on a well built 2.5L.
My best 1/4 mile time to date is et.12.42 @ 109.76mph with 1.92 60's. on 22psi via custom 3 bar cal. I want to run 27 to 30 psi and see what the GLH will do.  I want to know if a simple granger will do?
I want in the 11's bad
It should. If not, you can lock the wastegate closed with a vacuum pump. I used to do that when I maxed out the stock turbo.
