Old 10-30-2005, 11:36 AM   #1
problem with boost
My Ride: 91 Sundance RS
Ok so i have my manual boost controller set to about 13psi, so that when it spikes it doesnt hit cut off. anyway, today on the way home from the races i noticed it will go full 15psi and then drop off almost instantly to 7 and hover between 7 and 10. i know the stock gauge isnt accurate but you can actually feel and hear the engine lose power when the boost drops.
and i know its not hitting cutout because the engine still pulls hard and accelerates. its hit boost cut and i know its not doing it now.
Darkapollo is offline
Old 10-30-2005, 11:52 AM   #2
My Ride: 87 Z
Engine: 2.2 (+.040)
Check your intercooler hoses for leaks. Check vac lines for leaks. Make sure all clamps are tight, and zip tie the vac line connections.
87shelbyt2 is offline
Old 10-30-2005, 11:56 AM   #3
thanks, im changing out the intercooler today anyway so ill 3x over the connections.
Nicole Kidman Blog | Real Estate Investment | Guitar Lessons | Debt Consolidation | Pink Ranger
Page generated in 0.29810 seconds with 13 queries
