Old 11-25-2005, 02:34 AM   #1
whould this benifit me
My Ride: 89 omni;93 silverado
I have a garrett T2 turbo off the car and off the exhaust manifold... would it be better for me to leave it alone or put on a large can waist gate and a bigger swing valve... what if any performance would I gain??
Thanks inadvance,
Rob
Reble Rob is offline
Old 11-25-2005, 03:23 AM   #2
My Ride: GLH-T
the T2 garret should have the bigger wastegate can on it already...the bigger swingvalve would defintaly give you gains..but remember if you upgrade your swingvalve upgrade your exhaust to!
87DANCEonYOU is offline
Old 11-25-2005, 03:34 AM   #3
If you have the small can and are planning on running any more than 13psi or so then yeah changing it out would be a good idea. The swingvalve is a no brainer...but like was said do the rest of the exhaust and also if possible the exhaust manifold should be ported too.
dwh4784 is offline
Old 11-25-2005, 07:17 AM   #4
thank you guys
Old 11-25-2005, 05:24 PM   #5
87-88 TII cars came with the small can. I run a small can on my shadow, and it will hold 22PSI with a couple of washers to shim it.
The exhaust is obviously a huge upgrade. A 2.5in. SV would be a good upgrade if you can get one for cheap, but a 3" won't show huge gains like that money could get you elsewhere, assuming your setup is relativly stock.
OmniGuy123 is offline
Prepaid Credit Cards | Bankruptcy | Credit Card Shop | Cheat Codes | MPAA
Page generated in 0.30349 seconds with 13 queries
