11-29-2005, 03:23 PM
My Ride: Dodge Spirit R/T
Engine: 2.2L Turbo III
I didn't even realize it was you until after I replied! I was trying to get Josh to install one on the GTS, but it really needs a BOV first. When it was on the dyno, it was off-the-scale rich as soon as it spooled up. I would think the fuel system would be OK up to ~16 psi, but I would not go any higher than that with those injectors.
Dialing in the overboost eliminator is a two person job. When I install them on my cars, I run long extension wires from the MAP sensor to inside the car so that MAP voltage can be monitored while driving. I drive while Josh monitors the MAP voltage. The MBC (grainger) must be adjusted so that it will just barely hit overboost in the 4th gear. If the boost is set too high, it will hit overboost before you can zero in on what the MAP voltage is. After hitting overboost a few times, it should be easy to tell at what voltage overboost is occuring. On my cars, it seems to be around 4.2v, but your mileage may vary. Next, splice the overboost eliminator onto the long MAP extension wires. Go for another drive and have slowly turn the overboost eliminator down so that the maximum MAP voltage goes down until it is just below the overboost voltage threshold, say 4.15v.
I housed the overboost eliminator circuit in an old gutted keyless entry module from a GM W-body and stick it to the inside of my glove box with a piece of sticky back velcro. After the overboost eliminator circuit is dialed in, you shouldn't have to adjust it ever again, but you might want to check that it's functioning properly every so often just to be sure.
