Old 12-13-2005, 09:34 AM   #16
My Ride: 89 Chrysler Daytona
Engine: 88 2.2 T1-T2 upgrade
Originally Posted by 86lance
what would the asd relay do to cause it to feel like over boost around 8-9-10 psi? could the asd relay,cause this problem ANd a fuel pump problem?
When you overboost it triggers the asd relay, so yes asd would feel exactly like overboost, it would kill the spark and the fuel.
If the wastegate was unplugged you would get full boost.
daytonajesse is offline
Old 12-13-2005, 01:53 PM   #17
My Ride: Dodge Daytona
Engine: 2.2 liter turbo
no not unpluged the rod connecting to the wastegate from the turbo could be loose u will still get boost just it might overboost cause its all over the place ?
Daytona_Geoff is offline
Old 12-13-2005, 03:07 PM   #18
My Ride: 1986 lancer ES
Engine: t1 135
the wastegate vac line is just fine,let me restate what i said,the wastegate arm to the swignvalve is fine
86lance is offline
Old 12-14-2005, 08:22 AM   #19
How much vac are you pulling at idle? Should be around 20hg
Old 12-14-2005, 03:52 PM   #20
Engine: t1 135
im getting 18-20
86lance is offline
Old 12-14-2005, 08:07 PM   #21
Just today I had an issue where I overboosted at 9 psi, it was caused by a leak to the map sensor line in my map g-valve. When the map code is tripped it limits boost to 9 psi, I think the coolant temp sensor does the same thing.
Old 12-14-2005, 08:18 PM   #22
Engine: t1 135
ur map sensor g valve? Would that be so u can run over 14.7 lbs of boost? My coolant temp sensor is sort of loose and the only vac line i havnt replaced was the soft line that turns into a hardline for my MAP sensor,maybe i should get on that,lol
86lance is offline
Old 12-15-2005, 08:26 AM   #23
yeah my g-valve for the map is to run over 14.7psi. Those hard plastic vac lines tend to crack and it is hard to find where. I would replace it with a new rubber one. As for the cts just snug it up and make sure the wiring looks good, I dont think the coolant temp sensor fails very often.
Old 12-21-2005, 06:21 PM   #24
Engine: t1 135
damnit,i finished up my new boost controller and now the little shit wont start!
86lance is offline
Old 12-23-2005, 04:06 PM   #25
I had that happen to me once when a vac line popped out by the brake booster, Car was normally runnin 20 psi on fwd stage 4 cal. when the line popped of, only hit like 7 psi and hit cutout after a couple seconds on the gas. Maybe the computer was confused at full throttle and only 7 psi so it decided to cutout??? ;-)
-Jerry
sandmcrew2 is offline
Old 12-24-2005, 12:44 AM   #26
Engine: t1 135
not sure,i really gota figure this no start crap out first tho
86lance is offline
Mortgage | Internet Advertising | Personal Finance | Compare | Online Loans
Page generated in 0.50277 seconds with 13 queries
