12-17-2005, 01:17 PM
I know that the Ford 2.3L's and the Dodge 2.2L's have different characteristics, having the only real similar things is close displacement, and 8 valves, but as my car sits, other than a few small things, which are more tuning related, and my catback removed, its bone stock with a T3/T04B V-trim, and it spools pretty quickly to my amazement, thats with a stock exhaust manifold. The reason i say port the exhaust manifold is because the turbo dodge manifolds look very puny compaired to even a stock E6 casting for manifold, if you were able to port it out to at least match the fords, have a good exhaust on it; it will still spool nicely. Plus, while you have it off, its the perfect time to do some porting.
If money is an issue, the parts to build my turbo were all second hand, and off of factory cars/trucks. The T3 with the .63 housing was off of an 84-86 Turbo Coupe, and the T04B housing, backing plate, and wheel were off of a diesel of some sort.
