12-18-2005, 10:18 AM
Another 3.0 Turbo "How To"
My Ride: 94 Plymouth Duster
Engine: 6g72 181c.i.d.
Ok, I think I'm ready to put my turbo set up together. I want a good turbo (that will work well w/ my engine) and I'm going to use a large front mount and have my buddy set up the IC plumbing. Is a T04E too big? Is a stock garret 89 chrysler 4cyl turbo too small? I want 5 psi and I'm going to upgrade the fuel pump, and injectors. Pump will be a Walbro 255 and the injectors will be mustang 30# injectors. I have my AFPR and it works great. Basically I am worried mostly about which turbo I want. I want decent mid range and peak at 4000 RPM on boost. I will be getting most of my stuff from E-bay (Turbo, Swing Valve?, injectors, IC, BOV, and some silicone hose couplings.) Should I get a 4 cyl chrysler turbo pre-set @ 7psi w/ internal wastegate? I'm really worried about where I'm getting my crossover pipe made for turbo.
Mods to Date
UD Pulley
Timing Advanced
52MM TB
2.5" Straight Side exit exhaust
Heavily ported head, shaved, 5 angle valve
Crower Cams
Plenum Spacer
AFPR
-to name the basics.
I think I'm bout peaked on NA power w/o going into the bottom end. So I really want another 100hp until I'm content. Please give info and pics please.
