Old 12-18-2005, 09:23 PM   #1
te04h compressor questions
Hey, I want to replace the factory air box with a conical filter and associated piping. Also the discharge off of the compressor to the throttle body is soft and needs to be replaced. I was going to fab up a hard pipe for that as well. My question is what size is the compressor discharge and compressor inlet so I can order the silicon connectors. Thanks.
wallace is offline
Old 12-19-2005, 11:32 AM   #2
The outlet should be 2" OD. I am not certain, but the inlet is most likly 2.5" OD.
OmniGuy123 is offline
Old 12-19-2005, 06:45 PM   #3
Hey, thanks. The throttle body opening looks to 2 1/2" so I will get a 2 to 2 1/2" coupler for the outlet and just a 2 1/2" coupler for the throttle body....does that sound right?
wallace is offline
Old 12-19-2005, 09:37 PM   #4
My Ride: '89 Lebaron GTC TII
Engine: TII 2.2
Actually, i believe the throttle body is 2.25". The outlet of the turbo is 2" though.
I'm not sure what kind of piping you plan on using, but make sure you don't use pvc; especially in a non-intercooled setup. That little mitsu turbo heats up the discharge air REALLY well
aerosmith145 is offline
Old 12-19-2005, 10:31 PM   #5
yea dont use PVC... use abs! as long as you jb weld in some exaust pipe where the clamps are it works great!
TurboShadowES is offline
Old 12-19-2005, 10:40 PM   #6
Where did you get your ABS. I checked HD and a couple other places, but they did not have it. Only PVC. A little late now, but it would be good to know incase I am ever in a pinch.
Old 12-20-2005, 01:17 AM   #7
I was going to use mandrel tubing. I have some 2" left over from an exhaust project. So a 2" coupler for the compressor discharge and a 2 1/4" to 2" adapter at the throttle body. Thanks.
wallace is offline
Mobile Phones | Personal Loan | cPanel Hosting | Problem Mortgage | Car Insurance
Page generated in 0.28175 seconds with 13 queries
