12-27-2005, 05:09 PM
My Ride: Voyager
Engine: 2.5 .040 over cast
throw some rocks in there... yeah, that'll do it. get the exhaust manifold up to temp and pour water on it until it cracks? maybe...
12-27-2005, 11:16 PM
My Ride: 92 turbo duster
Engine: 2.5 turboo
Induct: S/C
1/4: 14.200
take off the intercooler pipe, remove the wastegate vaccum line, remove all oil & coolant lines, and then go floor it! that'll get her nice and hot lol Or you could take off the BOV, run lots of boost, and let compression surge rip the fins off lol You could also just wedge a screwdriver in it so it cant move, and then start it lol TAKE A VIDEO OF IT THOUGH, OK? I WANNA SEE LOL
12-30-2005, 04:22 PM
My Ride: Horizon GLH-T
Engine: 2.5L Turbo
Back when this forum had moderators, this kind of shit thread would have been deleted.
12-30-2005, 04:52 PM
My Ride: '90 dodge caravan
Engine: 2.5L
so basically you're angry and you wanna smash it?
if you remove the oil feed line to it, make sure you cap it off. the turbo takes oil from the engine to run so if it leaks it leaks oil out of the engine as well.
I gotta ask though, is this the kind of broke that you want it to be obvious what you did or you're trying to get it to die enough that the manufacturer will fix it correctly? "oh it only whines a bit thats fine. its not covered under warranty. oh it only smokes a little bit, thats not bad enough to need fixing."
12-30-2005, 11:40 PM
Engine: 2.5L
oil starvation might be your best bet. I think it'd look just like std wear and tear. find a way to cap the oil feed line, or remove the oil feed line and tighten a very short bolt into the hole it came from. it being a renault I haven't the foggiest what the threads are. try taking the oil feed line with you to the hardware store.
oh, and be careful when you take it off. I've broken the water feed fitting on my turbo at least once because I didn't brace it before I turned the wrench. douse the end of the line with penetrating oil before you mess with it.
anybody know more about renaults and could tell him how to remove the line?
12-31-2005, 03:17 PM
My Ride: 91 supra turbo
Engine: 7mgte 3.0
so is it dead yet?
12-31-2005, 03:30 PM
#12
My Ride: 89 Lebaron GTC
this is a cool thread!
12-31-2005, 04:28 PM
#13
My Ride: Daytonas
LOL
12-31-2005, 08:14 PM
#14
My Ride: 89 Shadow
Engine: 2.5 turbo
best and easiest way....... put a cinderblock in the road and make sure the oil pan hits it when you haul ass over it.//..
12-31-2005, 08:49 PM
#15
My Ride: 65 valiant
Engine: /6 225
They won't warranty crash/obvious external damage. Take it to the dealership and tell them it has left oil spots in your driveway. They will get under it find it is dry and send you on your way. Two days after the dealer inspection slice one of the turbos oil line with a razor blade at it's clamp. Make sure the slice is very close to clamp and fairly small. Clean all your personal items out of the car. Take it out and blow it to pieces. If you are really lucky a oil fire will occur and destroy the car. Of course intentionally destroying a car/major engine component and trying to make a warranty claim on it more than likely is considered fraud so everything on this forum is for hypothetical purposes. Good luck
