My Ride: turbo k car
Engine: 2.2turbo
sure,, an exhoust will give any car more power, especially a turbo car, as far as i know no/least backpressure,=good on turbo cars,, so go for a 2.5 or 3" youll notice it spool faster,,
most of the things you read about on this forum are 2.2 and 2.5 common block aplication,, but most of it applies,, run an intercooler,, front mount is best,, get yourself a boost gauge,, and air fuel ratio meter,, maybe even a wideband controll system,.,, then your ready for a boost controller,,
i dont know what the internals of that motor can take, but obviousely it will be able to take a few, maybe 5 psi more than stock boost as long as your not running lean,, or too hot,, ( be careful and do your research,, im sure someone here can tell you what they will take..
(disclaimer)I am not encouraging that you just start boosting the shit outtof it its not my fault if you blow your motor to bits,,
as far as turbo upgrades,, im sure theres a few tubos that will suit your setup, and give you more power, quicker boost or whatever you want,, but do your research and make sure the motor can take the power
ecm,, you can get into programming the stock ecu (something i know nothing about so dont ask,, or you could go standalone, (an aftermarket fuel and ignition controll computor that you program to run your car, as not to ever run lean etc. i recomend "megasquirt" as it is the most cost effective,,
as for other performance, i always suggest wieght removall, lightening a car icreases every aspect of the cars performance,, braking,, acceleration, handling,, (figures seeing that my other car is a completely stripped rx7)
other than that,, happy turbododge'n
-Paul
