Old 01-08-2006, 01:55 AM   #1
essential only vacuum lines
I was told that all the vacuum lines on my 86 turbo z weren't necessary and that with a grainger valve I could reroute and cut some lines. Does anybody have a diagram or can explain where exactly to reroute which hose to where?
Wormser is offline
Old 01-14-2006, 09:02 PM   #2
you only need 5 vaccum lines, map, fpr, wategate/grainger, blow off valve, boost gauge
at least those are the only lines i run on my 90
phaxtris is offline
Old 01-14-2006, 10:12 PM   #3
My Ride: No slicks Omni
Living in WA state you better feed the tiny heater control
vac line as well, need defrost up there
russ jerome is offline
Old 01-14-2006, 10:45 PM   #4
My Ride: 86 Daytona TurboZ CS
Engine: 2.5l 16v Hybrid
This is also something I've been trying to determine for my 16v Hybrid build. I'm trying to atleast clean up the engine compartment as much as my brother 88 T2 Shelby Z... tho I'm not sure if I'd be able to or not since it's an 86 T1 TurboZ. Been looking for info on this for awhile now.
ShadowGoomba is offline
Old 01-14-2006, 11:05 PM   #5
There is a sticky at top of this section, Gary has all of the
different year schematics on his site as well:
http://www.thedodgegarage.com/
Old 01-15-2006, 08:41 AM   #6
DOH!! That makes things easier, Thanks Russ
Old 01-15-2006, 02:15 PM   #7
eh, **** that, i live in manitoba, gets a lot colder here than in WA, just crack the window a bit and your good to go! (dont forget the toque, mits and jacket !)
phaxtris is offline
Myspace Layouts | Xbox Mod Chip | Debt Consolidation | Jewelry Store | Notebook Deals
Page generated in 0.32220 seconds with 13 queries
