01-10-2006, 07:54 PM
help with one of dempsey's recipes
My Ride: 89 Lebaron TII convt
Engine: 2.2 turbo II
i was reading this article on dempseys page
i have an 88 lebaron gts 2.2 turbo auto.
http://www.xmission.com/~dempsey/perform/nospike.htm
i understand everything on the page, and it is exaclty what i want to do too. but if i recall correctly, on the vaccum line coming out the wastegate can, there is another vaccum line coming from the top of the turbo inlet that tees into the wastegate can line. so what should i do with the turbo inlet vac line? since the wastegate line is running to other things now?
also, if i have it set to 14 psi, do i still have to worry about boost creep to overboost. because i have a full 2.5 madrel, no cat, ultra flo. or will the wastegate by pass enough air to keep me staying at 14 psi, until i let off? any help would be greatly appreicated. thanks.
