Old 03-14-2006, 10:46 PM   #31
My Ride: 89 Spirit ES 3.0
Engine: NA 3.0
So the spacers are only needed to clear the distributor?? So if I get rid of the distributor I wont need spacers to flip the plenum? I've never looked closely at a 3.0 before because I had always considered them junk motors. I'm starting to reconsider that though. I guess I've just always heard bad things about them
87turbodance is offline
Old 03-14-2006, 10:54 PM   #32
My Ride: 94 Dodge Caravan
Engine: 3.0L V6
Originally Posted by Ondonti
Wink you could always have tipped up the flange a little bit to get the turbo a bit higher if there is room after massaging.
The Shifter cables can be removed, and you can drill new holes and just have them go through the firewall higher up. My spirit conversion has the cables much higher then stock.
I did, after I shot these pics. Unfortunately, the angle and shortening the length from the flange, didn't make enough of a difference.
It was a worthwhile effort, and only cost me about $50 for all of it.
Lesson learned for me. Thank god I'm going with the twins.
mwinkle353 is offline
Old 03-15-2006, 02:32 AM   #33
My Ride: 93 LeBaron sedan
sp, where is the moderator, this should be moved to theturbo forum
Boogieman142 is offline
Secured Loans | MPAA | Loans | Mortgages | Mortgages
Page generated in 0.33170 seconds with 13 queries
