03-28-2006, 09:55 AM
#17
My Ride: 1987 Dodge Omni
Engine: 2.2, later 2.5 turbo
tell me if I'm wrong, but if you have a nicely built 2.5, it should spin the tires before it even begins building boost. By the time it builds boost, your car should be catching up with your tires. What I'm trying to say is that on a 2.5, I don't think it makes sense to have boost at low rpm. As it is you should need to go light on the throttle to keep the tires from spinning from rest. By the time you are able to actually floor it without tire slip, you should be seeing boost (above around 3k). That's the idea I used building the engine for my omni anyhow. A nice 2.5 in such a light car should spin those tires if it was naturally aspirated.
