Old 03-29-2006, 11:15 PM   #1
Holset Hot side removal
My Ride: 87 Shelby Z
I'm trying to remove the hot side housing on a HX35. I have the 4 bolts out that secure the two retaining rings, is there anything else I need to do to remove it? I've been soaking it with PB Blaster be it just isn't letting go. I haven't beat on it to much but I will need to get it seperated at some point in time.
Benji
bfarroo is offline
Old 03-30-2006, 06:29 AM   #2
If you've got all of the bolts out you'll have to beat the housing off of it. It may take alot of pounding to get it off. Good luck.
wallace is offline
Old 03-30-2006, 07:47 AM   #3
My Ride: 91 Shadow ES
I heated mine up and had someone hold it up on the cod side. then beat it with a hammer.took quite a while . I hope there not that hard to put back on.
90 c/s is offline
Old 03-30-2006, 08:25 AM   #4
Yeah that's what I thought, thanks for the confirmation
Benji
bfarroo is offline
Old 03-30-2006, 09:51 AM   #5
a little heat goes a long way...
xrattiracer is offline
Old 03-30-2006, 11:21 AM   #6
I used a turkey fryer!
turbodave/neon is offline
Old 04-02-2006, 10:38 PM   #7
My Ride: '89 plymouth voyager
you just dunked the turbo in the turkey fryer? I was gonna use our old one to make beer, but thats a damn good idea.
tkelly27 is offline
Old 04-03-2006, 06:17 PM   #8
I've heated it a few times with a map gas torch but that doesn't seem to be budging it either. I wouldn't think you could get it to hot could you? These things glow red hot when you beat on them in the car but they have oil going to them to cool the center section.
Thanks again.
Benji
bfarroo is offline
Old 04-03-2006, 08:38 PM   #9
the idea is to heat up the exhaust housing as quickly as possible while trying not to heat up the center section. and yeah, theres no way youll get it "too hot" with a handheld torch at the proper temp, the pb blaster that you sprayed on it will be smoking slightly.
Old 04-03-2006, 11:47 PM   #10
Yeah I had it smoking from the pb and still haven't gotten it to loosen up. I may bring in to work and gently heat it with the oxy/acc torch. That may get the outside to expand fast enough without heating the center to much and get it to slide off easily.
Benji
bfarroo is offline
Old 04-04-2006, 06:06 AM   #11
You have to beat if off with the hammer, heat helps but you still have to beat it off. Don't be scared to hit it hard. just work your way around the housing it will come off.
wallace is offline
Cheap Auto Insurance Quotes | Song Lyrics | Secured Loans | Loans | SEO articles
Page generated in 0.48416 seconds with 13 queries
