Old 03-31-2006, 11:55 AM   #1
Question Will this turbo Work??
I have an 89 2.5 with a mitsu turbo. Will this turbo work for an upgrade and if so, what would I need to make it work? All the info for it is below.
GARRETT TURBO SUPER 60 super60 New 57 Trim 60-1 50 Trim
Garrett Super 60 Turbo charger. A.R. 60 M 11.
The exhaust side is .48
It was on a 240sx 2.4L
Thanks
Vaughn
vsman77 is offline
Old 03-31-2006, 02:31 PM   #2
My Ride: '89 Daytona Shelby
I'm going to guess that exhaust housing flange is a standard T3 and will not bolt up without an adapter.
If you have a Garret exhaust housing section around you could consider swapping that housing over to it.
You need new lines too.
puppet is offline
Old 03-31-2006, 02:33 PM   #3
Thanks, would it be hard to get an adapter, and what would that cost?
vsman77 is offline
Old 03-31-2006, 03:07 PM   #4
I personally think you'd be better off swapping the housings. If the turbo isn't all rusted up it should take too long. Finding a dirt cheap replacement won't be too hard either. What's the exhaust pipe outlet set-up like on that garret you got?
puppet is offline
Old 03-31-2006, 07:03 PM   #5
My Ride: 86NewYorker88Horizon
Engine: 2.2 TI /2.2 tbi
Images: 19
if you swap housings it should work great.
srt-rex is offline
Old 04-01-2006, 07:56 AM   #6
Shadow's Avatar
1/4: 11.090
Images: 6
Now it could be just me, but it looks like you've listed enough info for 2 or 3 different turbo's there? Is it a 57trim or 50 trim?
Shadow is offline
Old 04-01-2006, 10:41 AM   #7
The turbo has A.R. 60 M'11 stamped on the side. It also has 2 chipped compressor fins. What would be the most I should pay for this turbo? And where could I get a housing from?
Thanks
Vaughn
vsman77 is offline
Old 04-01-2006, 11:24 AM   #8
How much should I pay for this turbo?
vsman77 is offline
Old 04-01-2006, 12:16 PM   #9
My Ride: 89 Dodge Caravan SE
Engine: 2.5 CB
I wouldn't pay anything for it if it has chipped compressor fins, thats likely to cause an unbalance screw something up.
SUPERVAN is offline
Old 04-01-2006, 12:17 PM   #10
Thanks
vsman77 is offline
Old 04-02-2006, 06:33 PM   #11
My Ride: '89 plymouth voyager
yup, that means the compressor has hit the housing, so the only thing thats good on it is the exhuast wich is pretty much exactly the same as a garrett in the junkyard.
tkelly27 is offline
Old 04-02-2006, 07:09 PM   #12
My Ride: CSXT
hell, I'll sell you my Garret for $150 when I replace it with a hybrid later this month.
juxsa is offline
Old 04-02-2006, 11:08 PM   #13
Let me know when you are ready...
Which one do you have and how good a shape is it in??
vsman77 is offline
Old 04-02-2006, 11:19 PM   #14
My Ride: CSXT
its a stock turbo 2 garret. ITs in pretty good shape. When I pull the head I will know in how good of shape. I am unsure of the mileage becasue I bought it second hand from a friend. I know there is no shaft play. Hopefully I will have it off by the end of the month. PM me so I will remember to get in touch with you.
juxsa is offline
Old 04-02-2006, 11:29 PM   #15
Thanks
vsman77 is offline
Advertising | Online TV | Cheap Gas | Credit Card Debt | Secured Loans
