04-03-2006, 01:35 PM
My Ride: 85 shelby charger
Engine: 2.2 liter I-4
Originally Posted by clocktowersnipr
Ya, a deisel and gas turbo is on in the same. They have nothing to do with what the engine fuels with.
I dont believe this is the case anymore, or if it even was true to begin with, but I was told at one time that a diesel turbo would not work and a draw through carb turbo setup on a gas motor. The reason being that supposedly the seals were different. On the draw-thru setup you will create a vacuum between the carb and compressor, and the seals weren't set up for the negative pressure and you would suck the oil out of the center housing and pump it right into the intake. Like I said this was only told to me, by several people I may add, but never talked to anyone who actualy had it happen.
