Old 04-10-2006, 09:39 PM   #1
wastegate solenoid, manual boost controller
My Ride: 85 lebaron & 03 taco
Engine: 2.2 turbo 1
i have a 1985 lebaron gts. i am new to this and cant figure out where to hook up my mbc. i have searched and searched and looked at thedodgegarage.com and the other schematics but i am still confused
can someone tell me where exactly my wastegate solenoid is and which vacuum source i should use to hook up my mbc?
i would appreciate the assistance.
dgr00s is offline
Old 04-10-2006, 10:14 PM   #2
My Ride: '89 plymouth voyager
if its a ball and check (g-valve) style, hook up the inlet (the side with the ball in it (another test: at the lowest setting you can blow into the outlet, but you can not blow into the outlet at any setting)) to the compressor outlet barb, and the outlet goes to a tee, 1 barb of the tee goes to the wastegate can, the other goes to the brass oriface. If this is still confusing I'm sure someone has a verry simple scematic. Also, you leave the solenoid out of the entire procedure, unless you want a 2 stage with the computer controlling the 1st stage (figure out how to set up the MBC before you try that). Hope that helps.
tkelly27 is offline
Old 04-11-2006, 04:44 PM   #3
Engine: 2.2 turbo 1
thanks for the info. turns out i need to replace the headgasket before i get to having too much fun.
dgr00s is offline
Virtual Private Server | Refinance | Free Advertising | Credit Card UK | Guitar Lessons
Page generated in 0.36542 seconds with 13 queries
