04-12-2006, 12:59 AM
My Ride: '89 plymouth voyager
Yes, you can set it up like that, but not quite the way you've described. It will max itself out, if you have it inline and ou have the switch shut off it will render it un-blow-through-able, so the WG will see nada. If you want to use that solenoid you basically have to set it setup like a MBC bypass. Take 1 tee from the compressor outlet (or whichever boost source you are using) send one side to the MBC and one to the solenoid, then have a 2nd tee taking the outlets from both and sending them to the WG. When the power is on, the solenoid will open and you get 4psi. If you are concerned about overboosting you should use a setup from a TD with the 3 barbs and have a boost switch so that over X psi it will flip the barb outlets and run you back to low boost, and you can have it setup in the case that the electricity gets cut off you'll be in 4psi mode 'till you hook it back up. Easy to set up, if you need a picture I can try and draw one for you.
