Old 04-24-2006, 07:59 PM   #1
crush BOV?
My Ride: 93 LeBaron sedan
Ok, one of my friends was talking about a 1g dsm crush bov. He knows nothing about it other than he was told you put it in a vice and crush it.
Boogieman142 is offline
Old 04-24-2006, 08:11 PM   #2
Feedback: (32)
and your question would be?
tryingbe is offline
Old 04-24-2006, 08:14 PM   #3
My Ride: '89 plymouth voyager
follow the instructions on the dodge garage. It'll hold just as much and you won't look stupid with a crushed can sitting in your intake. If you wanted to get really trick you could modify it even further so that the bottom of the actuator holds vacume (like in a canister) and then it would hold more boost than you or I will ever see.
tkelly27 is offline
Old 04-24-2006, 08:37 PM   #4
my question would be does anyone know anything about it.
Old 04-24-2006, 08:44 PM   #5
the dodge garage has nothing about the crush ones.
Old 04-24-2006, 10:28 PM   #6
so should i grab it from him before he throws it out b/c he thinks its junk.
Old 04-25-2006, 12:49 PM   #7
Feedback: (32)
http://www.google.com/search?q=crush...en-US:official
if those links are dead, use the cacheed feature of google.
tryingbe is offline
Old 04-25-2006, 08:54 PM   #8
My Ride: 85 GLHT, 87 ShelbyZ
DO NOT Crush it! Modify it like the Dodge Garage says too! Crushing it will slow it's response. Modify it and plug the modified line into a hobbs switch that seals it off at 18psi so it won't leak when you go above that. then at lower boost it'll open and be quick responding again.
GLHNSLHT2 is offline
Old 04-25-2006, 09:04 PM   #9
My Ride: 1987 Dodge Omni
Engine: 2.2, later 2.5 turbo
I think it it's junk - I'd rather buy one and modify it. They're not that expensive, and work much nicer. If you don't have anything right now, then I guess it's better than nothing, but if you have a little bit of money and time, just modify one.
Omnivore30psi is offline
Old 04-28-2006, 02:33 AM   #10
its only going to be seeing a little bit of boost so i will prolly use it as is.
Credit Cards | Free Ringtones | Loans | Internet Advertising | Loans
Page generated in 0.47615 seconds with 13 queries
