04-25-2006, 03:12 PM
GTCUL8R
My Ride: 1989 LeBaron GTC
Engine: Turbo II 2.2L/135ci
I believe the TC also came with a Turbo I, someone correct me if I'm wrong. Anyhow, look for the intercooler. If there is an intercooler it is the same Turbo II you would find in a Daytona or LeBaron and it would have the Garrett T3.
My CarDomain Garage
04-25-2006, 03:29 PM
Originally Posted by super chicken
Hello.
I have been looking around trying to figure out which turbo came on a 89 TC 8v engine. It looks to be a te04h but I see t03 mentioned, and I can't seem to find a definite if it is either a turbo I or turbo II engine.
I need to find a turbo for a TC I am probably going to be picking up, but I can't figure out which one would go on it. I would just look at the car, but it is an hour from me right now.
Thank you for your help.
TC came with either:
3.0 V6
2.2 TII Auto (detuned) - 160HP
2.2 Masi 16V
The 2.2 8V is a standard issue T2 with less boost to protect the weak automatic. It's kind of sad really, when you see how much power a well built A413 can take (stephane has like 700hp!) and yet they felt it couldnt handle 175hp?
FYI you can use either turbo, because they have the same pattern. However, it should have a Garret T03.
04-25-2006, 04:12 PM
Hello.
It suppose to have a Garret Turbo like all TII cars.
It is one of the two TII cars with automatic in the state.
04-25-2006, 05:45 PM
www.******************** for turbo rebuilt
Might want to check your local turbo stores too.
What kind of budget do you have?
Yes, you can built the automatic transmission as strong as you want.
04-25-2006, 06:01 PM
My Ride: 85 GTS, 3 87 GTS, 89
the transmssion god lives in your backyard in Ct. Cliff Ramsdell.
04-25-2006, 06:24 PM
I am assuming if I do try to get more power out of it, I would need a new exhaust, do something with the SMEC, and tranny. Laborwise its not a huge deal, I can probably do pretty much everything myself. (besides rebuild stuff, and know a really good tranny guy through a friend.)
I am not trying to do anything ridiculous, just try to up the power some. I guess 8ish second 0-60 or before I run out of room in the factory fuel system. I'm still really undecided at this point honestly.
Swap in a 88 or 89 TII computer, instant 14hp gain and upto 200lb ft of torque. Put a G-valve in and have it set at 14psi, that's about where the limit is on those stock TII injectors.
04-25-2006, 06:34 PM
Sounds like a plan. Now is there an easy way to set those g-valves, or will I probably have to grab a boost gauge?
Will the transmission in it be able to handle that?
And after really thinking about it, I don't think I would want to do much more than that. Maybe that, exhaust, drop in filter, nothing amazing. This car is just sort of an opportunity to drive something neat for a while, then maybe sell it and make some money. I should just leave it mostly stock, and just have less problems to worry about. Changing the transmission is just too much money and time into something that I am probably not going to keep, I actually really dislike automatic cars.
So, I guess it comes down to, could the stock transmission take the new computer, an exhaust and an intake with out blowing up? Or are they really just miserable peices of engineering?
04-25-2006, 10:47 PM
#12
the transmission can be modified to take anything you can dish out. Cliff ramsdell has a street strip for sale for $600 right now. You still need a torgue converter for it. For stock look, the bigger exhaust fwd.com, TU for 3" swingvalve and downpipe (backordered) , bigger turbo, ported head with bigger valves, ported intake exhaust mani, The bottom end is forged except pistons. TU cal and turbo forged pistons.
g valve directions. http://www.backesfamily.com/TCProjects/
Also has directions on repairing the odometer that breaks in every one.
09-14-2007, 02:11 PM
#14
TII in TC
My Ride: Chrysler TC by Mas.
Engine: 2.2L T2
I've been trying to find a SMEC from a Daytona TII to replace the detuned TC SMEC. I look for part #'s 5233246 & 5235069. Anyone know if other 88-89 Daytona SMECs will work? I was told only manual Daytona SMEC would work...
