Old 05-03-2006, 03:43 PM   #1
Vapor Canister Fuel mileage.
My Ride: 89 Shadow
Engine: 2.5 litre
Hey just wondering if not having my vapor canister not hooked up and just plugging the two vacuum nipples coming out of the TB would effect mileage much? Or does it at all cause i would rather get rid of those and get rid of a couple of more hoses.
H3M1 is offline
Old 05-03-2006, 04:52 PM   #2
My Ride: '91 Spirit R/T
Engine: 2.2 TIII
What the vapor canister does is collect the vapors from the fuel tank and admits them into the engine as it can use them. Bypassing this altogether will hurt mileage slightly (nothing earth shattering). However, if you just "jumpered" the hoses from the tank and throttle body with a small orifice (0.020" or so), you could get better mileage than with the canister.
Mike
mpgmike is offline
Old 05-03-2006, 08:00 PM   #3
My Ride: 89 LeBaron & 99 WS-6
Engine: 2.5L turbo & 5.7 LS1
the computer also purges the canister when it sees a lean condition too. I would keep it in, it dosnt really rob you of anything and it helps from poluting the environment.
LynX853 is offline
Old 05-03-2006, 08:18 PM   #4
My Ride: 87 ShelbyZ/86 TurboZ
Engine: 2.2L TII .30 over...
i also always wondered about that canister. Once the top popped off, and a spring came out, now the spring is gone...is that effecting anything on my car?
87shelbyZTII is offline
Old 03-04-2007, 06:50 PM   #5
My Ride: 85 GLH-T, 03 Cobra
Engine: 2.2 T1
Mike
Can you explain that a little more in depth?
VIPERBLUELX is offline
Old 03-04-2007, 09:42 PM   #6
Show me your g-valve
Lebaronguy2001's Avatar
My Ride: '89Baron, '04Stratus
Images: 19
i removed mine to clean up the engine bay a while back, never seen any ill effects as of yet. didnt notice a change in milage, and havent even had a fuel smell from the tank vent. its run with a small vac hose through the pass fenderwell and down behind the plastic inner fender shield...
Lebaronguy2001 is offline
Mortgages | Real Estate Investment | Personal Car Finance | Debt Consolidation | Guitar Lesson
Page generated in 0.33735 seconds with 13 queries
