Old 05-07-2006, 12:55 AM   #1
snoking turbo but turbos ok
ednutcracker's Avatar
My Ride: 89' Dodge Daytona ES
Engine: 2.5 l4
my turbo was smoking after first install, it is a rebuilt unit so i took it to a turbo service shop and they say the turbo is perfect... it smokes real bad and ive turned the engine on without the turbo and its flawless, i have a custom oil return setup but its a 5/8 hose and its real nicely routed i dont think thats my problem at all ,, what you guys think?
Ed
ednutcracker is offline
Old 05-07-2006, 02:49 AM   #2
My Ride: 94 shadow base coupe
Engine: 2.5 TBI
how long did you run it for when the smoke started? could it be the assembly grease/oil that was used during it's rebuild that was just burning off?
bluneon is offline
Old 05-07-2006, 07:46 AM   #3
My Ride: '89 Daytona Shelby
Originally Posted by ednutcracker
... it smokes real bad and ... i have a custom oil return setup but its a 5/8 hose and its real nicely routed i dont think thats my problem at all ,, what you guys think?
Ed
I think this is your problem. What's the slope?
puppet is offline
Old 05-07-2006, 01:18 PM   #4
Engine: 2.5 l4
at first i tough it might be grease in the manifold and stuff but it was smoking real bad and trowing alot of oil to the swingvalve
Old 05-07-2006, 01:25 PM   #5
Engine: 2.5 l4
what slope means? sorry
Old 05-07-2006, 01:33 PM   #6
Engine: 2.5 l4
thanks cris ill use it as a debugging guide when i get the turbo back on the car, the turbo was sold as rebuilt and 0 miles, i took it to the shop and they told me it looks perfect, as for the set up its a tbi to turbo convertion and i made the reurn line with a turbonetics oil return flange hooks up to a 5/8 fitting and to a 5/8 hose its real big and the hose dosnt have serious angles to it,
before removing the turbo i did this:
remove the oil supply line, blocked it of the sending unit, and i added oil to the turbo manually, i turned on for 10 seconds and added oil and it didnt smoke then sometimes it would smoke a little , no reving to the engine was done
i do not have a pvc valve i have the valve cover open to athmosphere
i used a gasket for the oil retun flange in the turbo , no rtv
Mortgage | Car Insurance | Loan | Mortgage | Advertising
Page generated in 0.38918 seconds with 13 queries
