Old 05-18-2006, 06:52 PM   #16
Resident piston cracker
crazymadbastard's Avatar
My Ride: 92gtc vert
Engine: 2.5 8v
Feedback: (20)
turbo oil feed line do interchange- oil drainback is def different. the gaskets to the drainback fitting is also different. You can also use your inlet outlet lines from the t1 till you decide to intercool it.
Come for a dyno run NEW Get-together 2-23-2008 @ 10am
http://www.turbododge.com/forums/f1/...-dyno-day.html
crazymadbastard is offline
Old 05-19-2006, 08:36 AM   #17
Originally Posted by jdawg
the part that bolts to the trubo then the exhaust bolts to
You mean the exhaust manifold or the downpipe?
dalek is offline
Old 05-22-2006, 06:46 AM   #18
I guess I should throw in a picture to show what I am talking about, right?
dalek is offline
Old 05-22-2006, 07:39 AM   #19
My Ride: daytona ES
thats a mitsu. the swing valve is built into the turbine housing. on the garret the swingvalve is part of the bolt on 90 degree turn coming off the turbine that you hook your downpipe to
sgt rj is offline
Mobile Phones | Car Insurance | Loans | Mortgage | MPAA
Page generated in 0.26353 seconds with 13 queries
