Old 05-31-2006, 12:48 PM   #1
What engine for a Super 60 turbo?
My Ride: '91 Shadow Vert
Engine: 2.5 turbo
Let me reverse the usual question: instead of what turbo do I need for this engine etc., I'll ask what 8V engine combo do I need to get the best out of a Super 60 turbo? I have a 2.5 with Venolia's and will run 21 psi. What else do I wrap around that S60?
John B is offline
Old 05-31-2006, 01:30 PM   #2
My Ride: CSXT
Ported Exhaust mani... Heat coated even better. A mild port job on the head with back cut valves. I would do more with widening the ports and not worry so much about the bowl area... maybe just kinda smooth the bowl.... I would stick with the 782 head. If you get get some work done of the runners of the intake mani I would. And a good IC. That would be killer
EDIT
I just saw that you had a Steve M head.... from what i tlooks like in your sig, you already have a killer setup fo rhte super 60. You should have hardly any lag and killer boost response.... you should be making good power.
juxsa is offline
Old 05-31-2006, 05:07 PM   #3
My Ride: 89 omni & 90 T1 shad
Engine: 2.5L HX-35 w/alcohol
i have a 2.5 with nicely "pollished" intake runners and manifold and madly ported exhaust and manifold, no cut valves or anything though. my S-60 spools very fast considering the size and will shoot to 28 psi as fast as a mitsu could (not that it could hit 28psi though).
turbo minivan is offline
Old 05-31-2006, 11:04 PM   #4
Shadow's Avatar
My Ride: 86 S/C
Engine: 2.2 8V
Images: 6
Like already mentioned, everything in your sig should do nicely. The I/C is even a little overkill but doesn't hurt to have a little more cooling than needed. All you need now is 255l fuel pump,+40's, FWD recal, 3 bar map and away you go!
Robert Mclellan
[SIGPIC][/SIGPIC ]
Shadow is offline
Old 06-01-2006, 12:23 AM   #5
Engine: 2.5 turbo
I have all that too except I'm waiting for my cal back like everybody else. I know you use the 88 turbo cam too; what do you think of the S-1?
John B is offline
Old 06-01-2006, 10:09 AM   #6
Shadow's Avatar
My Ride: 86 S/C
Engine: 2.2 8V
Images: 6
I've only ever used the 88-89 turbo rollers, because their roller cams and at high boost they work extremly well. I've built a few cars with the S-60 slider cams, years ago, they might have made a little more power at lower boost but they wear out and I don't like the slider design. I've often thought of trying one of the Taft offerings, but untill I hit a wall(and I haven't yet) I'm sticking with the stock exhaust mani and stock turbo roller.
Robert Mclellan
[SIGPIC][/SIGPIC ]
Shadow is offline
Old 06-01-2006, 10:32 AM   #7
Engine: 2.5 turbo
It is logical that with the tight timing and more lift that the S-1 could only be an improvement over the stocker. However, logic doesn't always hold true. Is your ex manifold ported?
John B is offline
Old 06-01-2006, 08:32 PM   #8
Shadow's Avatar
My Ride: 86 S/C
Engine: 2.2 8V
Images: 6
Most definatly!
Robert Mclellan
[SIGPIC][/SIGPIC ]
Shadow is offline
Old 06-02-2006, 12:05 AM   #9
Engine: 2.5 turbo
I just ordered an F2 cam from FWDP last night. It's supposed to be somewhere between the S-1 and S-2 (I don't have the specs yet).
John B is offline
Loans | Mobile Phone | Loans | Loan | Mobile Phone
Page generated in 0.40534 seconds with 13 queries
