Old 06-16-2006, 02:47 AM   #1
Non Intercooled Blow off Valve Applications
My Ride: 1985 Omni GLH Turbo
Engine: 2.2L I4
Images: 4
I was reading up on Garrett Turbos tonight and came across this "The BOV should be installed between the compressor discharge and the throttle body, preferably downstream of the charge air cooler (if equipped)." I'm wondering if anyone here has installed a BOV on any non intercooled T1's. I have an 85 Omni GLH T1 and I am curious about installing a BOV sometime soon, but don't want to convert to T2 or intercool just yet. Any opinions/info would be greatly appreciated. Thanks.
farazshah is offline
Old 06-16-2006, 08:50 AM   #2
It's not about being intercooled, its about being a blow through system. In your case, the early T1's were a suck through system and do not need, nor can they use, a BOV.
anonymous_user is offline
Old 06-16-2006, 11:50 AM   #3
Blow Through, Suck Through
Engine: 2.2L I4
Images: 4
Is there someplace that has more information about the differences between to the suck through and blow through systems? I'd like to know more about my turbo system.
Old 06-16-2006, 11:59 AM   #4
thedodgegarage.com Click on turbo database on the left it has everything you'll ever need to know about our cars
89turbomini is offline
Old 06-16-2006, 12:35 PM   #5
speedyshelby16's Avatar
My Ride: Shelby Charger
Engine: 2.2 turbo II
Images: 8
Your setup starts with the trottle body then goes to the turbo and then the intake. So if you where to put on your car it would even work and secondly if it did you car would have a massive vac leak.
Blow through starts with the turbo (sometimes a intercooler) then trottle body and then intake.
The reason for a bov is release the pressure from the turbo when you shift or let up so don't have stacking from the pressure since there nothing to cause staking it not a problem.
Check them out.
speedyshelby16 is offline
Credit Cards | Car Credit | Loans | Anime | Credit Card
Page generated in 0.39728 seconds with 13 queries
